OPL3LPT : OPL3 FM Synthesis on parallel port
Reply 240 of 267, by Eimer
matze79 wrote on 2021-09-05, 09:36:
Look inside the Devices Manager for LPT.
It pretty sure use entirely different address.
It may only support legacy printers.
yea I did there is an option to set "legacy Port support" but it doesn't work.
I can't set the port manually.
Reply 241 of 267, by digger
Eimer wrote on 2021-09-04, 12:24:
Just wasted an entire friday getting my OPL3LPT to work on windows 10 using a LPT PCIe card with asix chipset.
tried many configuration including its legacy port support but Scummvm couldn't open port 278,378 or 3bc
Vincent Bernat implemented OPLxLPT support in ScummVM through use of the libieee1284 parallel port library. This library usually does a good job in terms of hardware abstraction, and only falls back to the legacy PC I/O ports that you listed if there is no other way to detect the I/O addresses of the parallel ports in the host OS. Or at least that's how the library works on UNIX-like (POSIX) operating systems. See his merge and the accompanying discussion here: https://github.com/scummvm/scummvm/pull/1137
So you might want to try this in Linux for better results. Alternatively, you could ask the libieee1284 developers to improve Windows support, or make such an improvement yourself and create a pull request for it, if you have the skills and time for it.
Reply 243 of 267, by matze79
Well some cards can be forced to legacy ports you can try select resources in device manager (if possible)
Reply 244 of 267, by Eimer
matze79 wrote on 2021-09-05, 20:59:
Like I said there is a setting to enable legacy port support but you can’t select the port.
And by Ressources you mean the i/o area? I can’t see how to change that
Reply 245 of 267, by dreamblaster
OPL3LPT on HP200LX, planet X3 : https://youtu.be/BHppkTP0vUA
OPL3LPT on HP200LX, Leisure Suit Larry 3: https://youtu.be/FIowI1GXh94
more soundcard demos coming soon at the new HP palmtop youtube channel : https://www.youtube.com/channel/UCCVChzZ62a-c4MdJWyRwdCQ
(check it out)
Thanks for your support !
Reply 246 of 267, by my03
hi Dreamblaster
the opl3 arrived today and i was eagerly trying it out (using the tsr on my dx2-66 laptop). but i need some advice - neither Doom2 or Duke3d plays any music (both setup using adlib). would these require exe-patching or should the tsr be enough? i have no issues when playing the opl test music
Reply 247 of 267, by dreamblaster
my03 wrote on 2021-12-06, 20:48:
hi Dreamblaster
Hi
yes, for games using protected mode, it needs patching.
Adpatch should do the job for duke nukem 3d and doom II : https://github.com/pdewacht/adlipt/releases
Have a look at the demo pack too ? The Unofficial OPL2LPT and OPL3LPT demopack (for convienient testing of Adpatch)
Reply 248 of 267, by my03
dreamblaster wrote on 2021-12-06, 21:18:
Hi yes, for games using protected mode, it needs patching. Adpatch should do the job for duke nukem 3d and doom II : https://gi […]
hi Dreamblaster
Hi
😀 Thanks.
Duke3D now works perfectly.
(not lucky yet with Doom2 or Doom as they hang on the "initializing...." bit)
Reply 249 of 267, by dreamblaster
Can you try the doom from the demo pack first ?
Reply 253 of 267, by dreamblaster
Completing a new revision of opl3lpt : OPL3LPT V2
- soundchip showoff at bottom side
    108.28 KiB
    240.92 KiB
Reply 254 of 267, by matze79
Great !
What are the benefits of the new Revision ?
Reply 255 of 267, by dreamblaster
- producable again !
- showoff of sound chips at bottom side, also easier to replace these
- should be compatible with existing 3d printed opl3lpt cover (but maybe a new will be designed)
Reply 256 of 267, by 7F20
dreamblaster wrote on 2022-10-19, 13:59:
Very much looking forward to grabbing one when they exist again. Is there some kind of timeline for production at this point, or is it "sometime in the future?"
Reply 257 of 267, by dreamblaster
7F20 wrote on 2023-03-24, 18:24:
well i made a few prototypes and they worked well, i sold these
next up is making a larger batch
i think in about 1-2 months i will have more
Reply 258 of 267, by 7F20
dreamblaster wrote on 2023-03-24, 21:58:
Sweet. Yeah, sign me up!
Reply 259 of 267, by kirikl
Anybody interested in compiling Windows 3. X driver? Just asking, There is resources with non usual lpt address though, So I think it has to be redirect to 378, but in bin file there is wrong address. I can't make this file, can somebody please?
https://github.com/andreiw/adlib21
Thank y'all!
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
