Reply 80 of 267, by Jo22
If the PCB gets a little bit smaller in a future revision, it'll even fit inside a stock DB25 shell. 😀
    298.04 KiB
Reply 82 of 267, by dreamblaster
OK more stock arrived, I will be testing and packing this weekend.
OPL3LPT now available in the webshop, and through PM : https://www.serdashop.com/OPL3LPT
As a launch promotion I can offer you free 3d printed cover.
392.91 KiB
480.03 KiB
364.95 KiB
291.78 KiB
Thanks for your support !
Reply 83 of 267, by matze79
I like the OPL2 Case more 😀 Short circuit protection on the bottom 😁
Very good, please continue your work.
Whats next ? 😁
Reply 85 of 267, by dreamblaster
Could people that have OPL3LPT running, report back if it works fine on their PC's, and tell me which systems you tried ?
It should work fine with the same tools as for OPL2LPT.
(we are working on some OPL3 specific patches for some games)
Reply 86 of 267, by OPLx
It should work fine with the same tools as for OPL3LPT.
Hello! I received the OPL3LPT today, but unfortunately the line(power) noise is more audible than the actual FM output (even at full volume). 😢 The line noise is there whether or not the USB power cable is connected to the OPL3LPT. The machine I'm testing on is a Pentium 3/450 MHz machine, the motherboard is an ASUS P2B board. Is there anything that can be done to remove the line noise? I have an OPL2LPT and it doesn't exhibit this problem.
Reply 87 of 267, by dreamblaster
Hi,
do you have a 3d printed enclosure on your opl2lpt ?
--> The description sounds like the ground of the line out is not connected : Maybe the shape of your 3.5mm connector is too thick to fit through the 3d printed enclosure completely ? Maybe you have a different cable to use ?
Could you try the board without the enclosure, and fully insert the 3.5mm connector, see if the problem remains ?
Please let us know if this solves the problem.
All OPL3LPT boards were personally tested by me, on my setup. So I hope this can be resolved. I'm here to help if you have any issue.
Reply 88 of 267, by OPLx
dreamblaster wrote:
Hi, do you have a 3d printed enclosure on your opl2lpt ? --> The description sounds like the ground of the line out is not conn […]
Hi,
I just tried it without the enclosure and it works perfectly! 😀 Thanks for the suggestion; it didn't occur to me that that would be the cause.
Reply 89 of 267, by dreamblaster
I am very glad it is solved.
To use you enclosures, if you don't have a different cable, maybe you can enlarge the hole a bit ?
Alternatively a cheap extension cable can bring an elegant solution ? (for example this 1 euro one)
https://www.ebay.de/itm/3-5MM-Audio-Aux-Headp … -X/283041142144
170.56 KiB
Reply 90 of 267, by OPLx
Thanks for the suggestion! I pushed the 3.5mm connect a bit more closer to the case and that seems to work (for now). If the line noise happens again, I'll just make the hole a bit larger. Thanks for making such wonderful products! 😀
Reply 91 of 267, by dreamblaster
Quick test of OPL3LPT Mod for Adlib Tracker 2 : https://youtu.be/vu4S40F7Ptk
Supports native OPL3 support, so stereo sound 😀
Reply 92 of 267, by dreamblaster
For OPL3LPT users, wanting to try real opl3 mode music,
here's a zip file of the Modified Adlibtracker II DOS version, as it works on my DOS PC :
AT2P.zip
2.61 MiB
115 downloads
(this version only works for opl3lpt), not opl2lpt)
Reply 93 of 267, by dreamblaster
I did more recordings with OPL3LPT and adlib tracker :
FM63B_RV : https://youtu.be/-uZWNwA08Hk
1942 : https://youtu.be/s1WhzKOFTOk
Reply 94 of 267, by OPLx
I've added support for OPL3LPT to SBVGM. It can be downloaded from this link: http://www.oplx.com/code/
Some VGM data can be found here: Packs using YMF262
Please enjoy! 😀
Reply 96 of 267, by dreamblaster
Please enjoy! 😀
This works wonderfully ! Thanks !!
I recorded a demo : https://youtu.be/7vu-2HyxCtE
Reply 97 of 267, by OPLx
Please enjoy! 😀
You're welcome! Thank you for making awesome hardware! 😀
Reply 98 of 267, by dreamblaster
The new adlibtracker II build for opl3lpt can be found here : https://github.com/pdewacht/at2lpt/releases
Reply 99 of 267, by datajake1999
I added OPL3LPT support to my user mode OPL3 MIDI driver via inpout32.dll. I don't have an OPL3LPT, so can one of you install the driver to test it?
Here is how to test it.
You need inpout32.dll in C:\Windows
To enable OPL3LPT support, set oplhwsupport environment variable to "-lpt".
Enter the I/O address for the port in hex in the lptport environment variable for example "378".
The source is on github.
https://github.com/datajake1999/OPL3EMU
Edit: If it works, please post a recording of clouds.mid played on the Windows driver.
