First post, by matze79
Hi ppl,
I'm working on the Covox Speech Thing with a Chip DAC.
This is using a AD7524 Digital to Analog Converter, a LM358 OPAmp and the TDA7050 Amplifier.
There is also still Room for improvments of the Device.
It already sounds pretty clear and will hopefully beat R2R DAC's soon 😀
4.3 MiB
3.92 MiB
4.11 MiB
The CVX-1-4 inspired me again to dig out my old DAC800 and other Stuff i collected to make a Covox like Device.
As you can see it looks pretty good for now 😁
Homebrew PCB with tonertransfer method.
I need another Amp, because the TDA7050 is no longer in Production,
i thinking about using a Class D one.
But most of them that are suitable are BGA packages.. or MLF
Reply 1 of 7, by dreamblaster
wow, looks good.
let us hear it, too ! 😀
Thanks for your support !
Reply 2 of 7, by matze79
Yeah but TDA7050 is working in bridged mode, i don't think my line in will like it 😀
Need to grab Signal before the Headphone Amp then 😁
how do you record from your devices ?
just using line-in of my main pc isnt that good, i get additional noise that way
Reply 3 of 7, by dreamblaster
I use my Zoom Q4 : this has line in, and of course records video at the same time.
--> I upload this to youtube (no processing).
Reply 4 of 7, by matze79
I will try to record, as soon as i find a suitable configuration 😀
Designed a DropIn Replacment for TDA7050 in Bridge Configuration (Using LM386):
105.47 KiB
And i solder in a new Poti later.
Reply 5 of 7, by matze79
Bought some Cables for recording 😀
But i need to improve a few things.
The LM386 sounds pretty shitty.
The TDA7050 is far superior.
The LM386 sounds a little bit skewed.
Maybe i should try to generate some Signals and measure with the osciloscope.
Reply 6 of 7, by Super_Relay
If you have the LM386's handy still theres a good article here on getting the best out of them
https://hackaday.com/2016/12/07/you-can-have- … old-dead-hands/
I am working on a raspberry pi audio project of similar scale and was recently checking out what i could use for an op-amp as my output is not fantastic into headphones.
its sad the tda7050 and 7052 are all end of life parts now
Reply 7 of 7, by matze79
Hi,
i recorded Crystal Dream, Amplifier installed is LM386.
Record is not perfect, as LM386 is making some noise..
I want to try some Class D Amps and try to get some Samples 😀
Hear me:
https://soundcloud.com/matthias-werner-matze/ … stal-dream-demo
44Khz / Mono played by AMD K6-2 450Mhz
EDIT:
OPAmp Stage can be fine tuned.
A additional variable resistor can improve it a little bit.
But i need some program to generate some test signals to fine tune it.
