First post, by Skyscraper
Many people *cough cough* have probably wondered how many socket adapters you can stack! Just how far can you go before things just refuse to work?
This is the setup we are testing.
Socket 8 (VS440FX) ---> PPGA S370 (PL-ProII) ---> FCPGA (PL-Neo S370) ---> FCPGA2 (Lin Lin)
I bought these adapters along with a motherboard and some CPUs, the previous owner had probably tried to stack the adapters but failed .
Reasons that might have hindered him from succeeding.
1. The motherboard he used (and sold in the bundle) is known to not work with the PL-ProII.
2. The connector that fits on the PL-ProIIs little fan header on the power cable for the fan on the heat sink he used had plus and minus inverted (not the original PL-ProII fan).
3. The jumper settings on the Lin Lin did not match a configuration described in the "user guide" = back of the box.
With a Gateway 2000 Intel VS440FX motherboard listed in the supported motherboard list for the PL-ProII, the jumper settings on the Lin Lin configured for FCPGA to FCPGA2 and the little fan cable NOT plugged in I was ready for smoke test. The CPU used is a Tualatin Celeron 1400, the memory is the 64MB EDO and the video card a Matrox Mystique (2MB+2MB). I did not bother to update the BIOS as I diddn't even know what BIOS the motherboard had.
The big moment. I had never even powered on this exact motherboard before.
The motherboard POSTed pretty much instantly after I hit the power button. After the memory count I took this picture.
1.12 MiB
I entered the BIOS setup and it seems the BIOS can see the Tualatin Celerons cache just fine...
1.19 MiB
But does it run alright?
240.97 KiB
I know member luckybob gets "REALLY suspicious" of people with all too tidy work benches and/or computer desks. I just want to let you know that you can relax Bob.
1.35 MiB
Reply 2 of 10, by Skyscraper
luckybob wrote:
wow. I just got called out.
that said, i do eventually want to try a pair of 8 to 370 adapters.
I also want another adapt... or it's more like I NEED another adapter!
Dual Celeron Mendocino 533 (@560) running on a Intel PR440FX would be soo much cooler than an Abit BP6... Or perhaps a couple of PIII-S @735...
Reply 4 of 10, by vetz
Nice work!
I hope you'll do some benchmarks and test other CPUs and motherboards 😀
Would also be interesting to know if you need the PL-NEO 370 adapter.
Reply 5 of 10, by Skyscraper
vetz wrote:
Nice work!
Well of course I will play with my new toy!
Perhaps just not instantly. I will probably post some DOS benhmarks with the Celeron and the PIII-S tomorrow but I'm in the middle of some Socket 478 experiments and I dont want to get too sidetracked.
I will try to see if I can find a HDD with Doom and/or Quake already installed before going back to tinkering with my Pentium 4 stuff.
Reply 6 of 10, by meljor
Very nice!
I have some form of a ''cpu adapter fetish'' but didn't even know the socket 8 one existed. Nice stack and it seems to perform pretty good.
Reply 7 of 10, by Anonymous Coward
So you're getting 933MHz out of a Socket8 board? Not too bad. I bet not too many S370 chips were paired with EDO DRAM.
Reply 8 of 10, by Skyscraper
Yes 😀
I got sidetracked! Something suddenly came up.
Yesterday I had to prepare for today.
Today I have driven almost 1000km (=621.5 miles) in my small old crappy pick-up, carried 600kg (=1323) pounds of goods from the eight floor (I did get help) and now I'm carrying said goods up to my apartment on the second floor from the parking lot a fair distance away... without help... I will do exactly the same thing the next Saturday... and the one after that and probably the one after that aswell... 4 trips should be enough...
Reply 9 of 10, by feipoa
That sounds like a hearty exercise regime!
So you are running a Tueleron at 14x on a socket 8 board? Impressive. It would be neat to see such a setup in a dual CPU platform. It would also be interesting to benchmark the Tueleron 933 against a more conventional Tueleron system.
Is the system stable enough to install W2K or XP Pro?
How far can you take the system if using a PIII-S Tualatin? Is 10.5 the maximum multiplier? So 10.5 x 66 = 700 MHz? Were there unlocked samples? Can socket 8 boards be overclocked with a 75 MHz FSB?
Is PPro 180 to Tueleron 933 the largest leap in performance of any upgrade solution? I think Anonymous Coward was working on a socket 4 to AMD K6-III, which would make for a massive leap as well.
Reply 10 of 10, by Vegge
Skyscraper wrote:
Yes :) […]
Yes 😀
Sounds like great fun 😎
