Reply 80 of 299, by nd22
13. Aqua mark 3 1600*1200 max
nforce2:
391.89 KiB
GPL-2.0-or-later
425.34 KiB
GPL-2.0-or-later
kt880:
394 KiB
GPL-2.0-or-later
427.55 KiB
GPL-2.0-or-later
Reply 81 of 299, by nd22
14. Aqua mark 3 1600*1200 max + sound
nforce2:
391.17 KiB
GPL-2.0-or-later
426.95 KiB
GPL-2.0-or-later
kt880:
394.86 KiB
GPL-2.0-or-later
426.13 KiB
GPL-2.0-or-later
Even at this extreme resolution having hardware accelerated sound helps - nforce2 wins by 8%!
Reply 82 of 299, by nd22
15. 3d mark 2000 default 1024*768 default
nforce2:
139.48 KiB
GPL-2.0-or-later
kt880:
145.33 KiB
GPL-2.0-or-later
I considered using 3d mark 99 however that test is more suited for a Pentium 3/ geforce 4 platform and not at this level of performance!
Reply 83 of 299, by nd22
16. 3d mark 2000 1280*1024 max settings
nforce2:
139.5 KiB
GPL-2.0-or-later
kt880:
147.31 KiB
GPL-2.0-or-later
Reply 84 of 299, by nd22
17. 3d mark 2000 1600*1200 max settings
nforce2:
155.31 KiB
GPL-2.0-or-later
kt880:
156.39 KiB
GPL-2.0-or-later
Nforce2 continues to lead in this DirectX7 benchmark at all resolutions!
Reply 85 of 299, by nd22
18. 3d mark 2001 1024*768 default
nforce2:
285.43 KiB
kt880
77.27 KiB
In this DirectX benchmark which is considered one of the best system test for this era nforce2 wins by 6.69%. Anything over 5% I consider to be significant and have an impact in games.
Reply 86 of 299, by nd22
19. 3d mark 2001 1280*1024 max settings:
nforce2:
251.63 KiB
GPL-2.0-or-later
kt880:
79.47 KiB
GPL-2.0-or-later
Reply 87 of 299, by nd22
20. 3d mark 2001 1600*1200 max settings:
nforce2:
77.6 KiB
GPL-2.0-or-later
kt880:
77.6 KiB
GPL-2.0-or-later
Another test, another victory for nforce2!
Reply 88 of 299, by nd22
21. 3d mark 2003 1024*768 default:
nforce2:
61.54 KiB
kt880:
60.68 KiB
It would seem that the video card is already the bottleneck in this test however, as you will see, the devil is in the details!
Reply 89 of 299, by nd22
22. 3d mark 2003 1280*1024 max settings:
nforce2:
250.43 KiB
GPL-2.0-or-later
kt880:
61.3 KiB
GPL-2.0-or-later
Reply 90 of 299, by nd22
23. 3d mark 2003 1600*1200 max settings
24. 3d mark 2003 1600*1200 max settings no sound test
25. 3d mark 2003 max settings 24 sounds test
nforce2:
243.37 KiB
kt880:
245.59 KiB
The score seems pretty close, only a difference of 0.67% which is meaningless in practice however 3d mark 2003 ONLY takes into account the game tests when calculating the score! However I decided that I will take into account the sound tests as a separate result! Please note that only AN7 can do the test with 60 sounds as KW7 can not perform it so I did not include that in the final score!
The difference between nforce2 and kt880 in the sound tests is absolutely HUGE: 16.13% with no sound and 34.09% with 24 sounds! And keep in mind that it was performed at 1600*1200!
Reply 91 of 299, by nd22
26. 3d mark 2005 1024*768 default
nforce2:
57.5 KiB
kt880:
57.51 KiB
Reply 92 of 299, by nd22
27. 3d mark 2005 1280*1024 max settings
nforce2:
58.04 KiB
GPL-2.0-or-later
kt880:
58.04 KiB
GPL-2.0-or-later
28. 3d mark 2005 1600*1200 max settings
nforce2:
57.97 KiB
GPL-2.0-or-later
kt880:
173.98 KiB
GPL-2.0-or-later
IMHO 3dmark 2005 is too powerful and too new for this system in general and the geforce 7800gs in particular. This is the first time KT880 scores a win at 1280*1024 resolution, very small but still a victory!
Reply 93 of 299, by nd22
29. Tom 2d benchmark:
nforce2:
31.98 KiB
GPL-2.0-or-later
kt880:
31.77 KiB
GPL-2.0-or-later
In this test which was requested by swaaye VIA has serious problems in 2d and is strongly limiting the geforce 7800gs. Web browsing on the VIA system is much slower than on Nvidia; this could be a serious drawback for some users.
Reply 94 of 299, by nd22
30. PC mark 2002 – CPU
31. PC mark 2002 – RAM
nforce2:
55.21 KiB
kt880:
54.13 KiB
In the CPU test the difference is within the margin of error however in the RAM test 6.47% is significant and has effects in the "real world". FYI I also tested a KV7 - VIA KT600 system with the rest being the exact same hardware and software and there is practical no difference between it and the KT880 - dual channel does not bring any tangible improvements!
Reply 95 of 299, by nd22
32. PC mark 2004 – CPU
33. PC mark 2004 – RAM
34. PC mark 2004 – GPU
nforce2:
48.15 KiB
kt880:
48 KiB
nforce2 continues to march on adding 3 more wins to its tally! The total score should not be taken into account because the 2 system drives are NOT identical and in this particular benchmark I tested the SSD attached as a storage drive on the AN7 by mistake!
Reply 96 of 299, by nd22
35. PC mark 2005 – CPU
36. PC mark 2005 – RAM
37. PC mark 2005 – GPU
nforce2:
44.82 KiB
GPL-2.0-or-later
kt880:
44.76 KiB
GPL-2.0-or-later
Please note in this test the large difference between the GPU scores. VIA platform is limiting the video card.
Reply 97 of 299, by nd22
I decided to publish all synthetic benchmarks first so let's jump to:
47. Super pi 1m
nforce2:
203.61 KiB
GPL-2.0-or-later
kt880:
210.15 KiB
GPL-2.0-or-later
For the first time VIA has an advantage over nforce2 - 5.76%!
48. Cine bench 2003
nforce2:
229.91 KiB
GPL-2.0-or-later
kt880:
227.59 KiB
GPL-2.0-or-later
Back to usual: nforce2 wins in Cinebench 2003.
Reply 98 of 299, by nd22
The first of the game tested is Doom 3. This particular games is exceptionally GPU bound therefore I disabled AA in order to obtain meaningful results but all other settings are at the highest level. As with the other tests the first 2 runs have been discarded and the third has been saved.
44. Doom 3 1024*768 max settings - no AA
nforce2:
42.46 KiB
kt880:
42.06 KiB
Reply 99 of 299, by nd22
45. Doom 3 no AA 1280*1024 max settings no AA
nforce2:
59.34 KiB
kt880:
59.84 KiB
46. Doom 3 no AA 1600*1200 max settings no AA
nforce2:
74.45 KiB
kt880:
74.78 KiB
First game test, first win for nforce2!
