OAK OTI-037c - 800x600 mode ?
Reply 21 of 30, by retardware
tayyare wrote:
jesolo wrote:
(there might be a jumper to set it up for 16 bit or 8bit)
8-bit capable cards find out this by themselves. No connection of 16-bit ISA part = 8bit.
Reply 22 of 30, by Deunan
Jo22 wrote:
Edit: How about Realtek cards ? Just seen a few online, approx. from the same time period.
Stay well away from any Realtek VGAs. If you think the OAK you have is crappy, you'll find yourself at a loss for words when you test a Realtek. Both performance and video quality are terrible.
I found Trident TVGA8900D to be a good ISA card but it needs to have at least 512kB of VRAM. It will use 8-bit internal bus for 256k, 16-bit for 512k and 32-bit for 1M, although the speed difference between 512k and 1M is not that big, ISA becomes the bottleneck at this point. The output could be better filtered (or maybe its DAC has noise) but it's not bad - even if some people will consider it unacceptable in Doom for example. I also have a VLB Cirrus Logic 5424 and while CL cards have superior video quality in general, my card has some slight vertical pixel crawling in Doom so it's not like these VGAs are perfect. And CL is much more pricey plus I've found the Trident to have better VESA support but that is down to BIOS version/date.
Reply 23 of 30, by tayyare
retardware wrote:
According to my personal experience with Oak 067 card that I have, that's totally true.
But I see ISA VGA cards with "8bit bus / 16 bit bus" jumpers on them. I'm not sure if those jumpers are for something else entirely, So there is a"might" in the sentence. 😊
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 24 of 30, by retardware
Yes you can force them to work in 8-bit mode even when plugged into a 16-bit slot.
(this was explained for maintaining backward compatibility with some esoteric systems)
Reply 25 of 30, by Jo22
Hi everyone, just wanted you to know that I got myself an OTI-067 for testing.
It's apparently compatible to the VGAMODE utility of the 37c (it looks the same, at least),
so I'll do some testing next of the CGA and Hercules emulation modes ("Three Shades of Gray" demo on OTI-37c).
I'll also see if I can get the Windows 2.x drivers working on that card (-> thanks Elianda).
jesolo wrote:
While going through my "inventory", I also came across one that I have.
Has anyone perhaps tested an OTI-037 based card in an XT PC (i.e., does this 16-bit card work in the 8-bit slot of an XT PC)?
I've seen an 8-Bit 037c card a while ago, so I think the "full" 16-Bit version should work there, too.
What I also wonder is, whether or not such an early chipset would technically work in the other 16-Bit slots of the day.
Namely those based around the 8086 and NEC V30/V40 central processors (Olivetti M24, soviet XTs etc). 😀
PS: I also checked FractInt on the 037c. It did all the tweaked VGA modes,
but sadly, the SVGA mode didn't work (got an error message)..
Reply 26 of 30, by mixerjdp
Jo22 wrote:
Hi everyone, just wanted you to know that I got myself an OTI-067 for testing. It's apparently compatible to the VGAMODE utility […]
Hello! i have a question: Oti067 works in hercules mode in a monochrome monitor? the specs says that it only emulate MDA (text mode without graphics).
Reply 27 of 30, by Jo22
Hi, the DIP switchs on the back of the card do select the monitor type, which sometimes is also tied to a specific mode.
On a VGA monitor (maybe EGA monitor, too), several modes are available through the VGAMODE program.
Just select MGA for Hercules. MGA stands for Monochrome Graphics Adapter, in contrast to the text-only Monochrome Display Adapter (MDA).
I suppose they called it that way to avoid being sued by Hercules. A less generic term would be HGC, for Hercules Graphics Card,
Some games and applications of the 80s also say Hercules Monochrome (Card) in their setup programs.
Edit: I don't know the DIP switch settings right now, but you can have a look at stason.org (Tularc category)..
That place has got several drawings of graphics cards, along with these settings bein mentioned.
Reply 28 of 30, by Jo22
Quick Update. Just had a little bit of time for testing the 67c..
My guess wasn't so wrong, it seems. The VGA Mode selector program works whit it, as it did with the 037c.
Even more, it has the same glitches in PopCorn. Directly after running VGAMODE, the game is still pinkish.
This leads me to the conclusion, that the CGA emulation ciruit is similar to that of its predecessor.
Here's a little clip that I did a while ago to document that 37c "bug".
https://youtu.be/cu88uKmqlEU
Edit: I also checked the Windows and VBE drivers. VBE driver 67_VESA worked fine, providing VBE 1.1 (?).
The Windows 3.0 driver in 256 col also worked on Windows 3.1, after a bit of work. The Windows 2.x drivers provided 800x600 16col and 1026x768 (in 4col ?).
Unfortunately, they required Windows 286 and 386, in version 2.11. And I've got plain 2.03; non-286, non-386.
The 286 version might have worked, if the driver was written for 2.01 or 2.03 (Win286 is like the plain version, but supports HMA; it can run on XTs, too).
Edir:
tayyare wrote:
800 x 600 at 16 colors (4 bit) is ok for 256KB of video RAM
Just double-checked - Yes, seems right. 😀 Some card's Win 2.x drivers like that of the PVGA or ET4000 even supported 640x400 in 256 colours.
From what I found out, that's also the one and only more-than-16c VESA mode that works with 256KiB of RAM.
I find that kinda funny - 256KiB are the minimum for 256 colours. ^^
Reply 29 of 30, by Jo22
Update! Finally! Got the 800x600 mode work! 😃
Turned out that the DIP switch was preventing Super VGA resolution.
I played a bit with the settings and now it seems to be configured for NEC/Multisync monitors.
The sample pictures are borrowed from Mister Xiado's The Oldernet site.
Edit: Picture viewer used was 2Show.
Edit: I forgot to mention. I'm using the OTI-037C right now, the 067 had a similar "issue".
    387.61 KiB
    468.57 KiB
    168.53 KiB
    778.78 KiB
    913.12 KiB
Reply 30 of 30, by Kahenraz
Jo22 wrote on 2019-03-23, 06:07:
Okay, so I managed to split the ROM by using WinHex.
Unfortunately, I do not have got a pair of 27128 left and the original chips are OTPs..
Did you ever manage to get the new BIOS flashed to this? I just bought one of these as well and it has the same older 2.15-35 BIOS.
I also have an issue where sometimes there is no picture on bootup. I have to reboot the system several times before a picture will appear. This is frustrating when testing different jumper settings, since I can't tell if there is an incompatibility or there just isn't a picture displaying.
I have to use the following procedure to get VGA to detect with MechWarrior 2 setup:
* DIP switch on: 1, 2
* OTIVBE.COM (VBE 1.2)
However, I can't get a picture out of it that isn't corrupted.
1.07 MiB
