Boxedwine (Wine on multiple platforms)
Reply 40 of 88, by Agathosdaimon
i extracted it and run te boxedwine exe but nothing happens, i am assuming i need to add/install someting into it? i am running windows 10 64bit myself
Reply 41 of 88, by danoon
Boxedwine doesn't have a nice UI like Virtualbox/VMWare. It's purely a command line app that requires arguments in order to run. You can double click one of the bat files to run a demo I included, like FullTiltPinballDemo32.bat, if you downloaded the recent beta.
Someday it would be nice to implement a more user friendly UI, but for now I'm just focused on performance and compatibility.
If you are trying to run a game that was meant for Windows 95/98 that doesn't use Direct3D, then I would say there is a 75% chance it might work.
http://www.boxedwine.org/
Reply 42 of 88, by Agathosdaimon
Oh okay thanks - i guess i would be looking for somethign that can run direct 3d - i am trying to get games like Jane's F/A-18, iF/1-18 and other late 90s, early 00s sims working
Reply 43 of 88, by danoon
					TCHAR Ch[1024];
ANSICHAR ACh[1024];
appSprintf( Ch, TEXT("%s: %s%s"), FName::SafeString(Event), Data, LINE_TERMINATOR );
INT i;
for( i=0; Ch[i]; i++ )
ACh[i] = ToAnsi(Ch[i] );
ACh[i] = 0;
LogAr->Serialize( ACh, i );
This is some code from Unreal found at https://github.com/stephank/surreal
Notice how there is no string length check for Data? I now pass back the OpenGL extensions list from my computers hardware and I guess it was too big for such an old game.
I am unable to run this particular version of Unreal.exe on my desktop Windows 10 machine as well.
Now Boxedwine will support a new command line argument -glext which can be used to filter the gl extensions the host computer returns.
This also fixes Quake 2, probably for a similar reason.
Quake 2 is hitting some pretty fast numbers now, I attached a screen shot showing 560 fps
    334.91 KiB
Reply 45 of 88, by danoon
I looked into F/A-18, but I couldn't get it to work. Wine app db says that people haven't had luck with it on Wine, and since I use Wine, I'm not sure how much luck I will have with it. https://appdb.winehq.org/objectManager.php?sC … cation&iId=2184
Even though I just said Direct 3D games won't work, I had a break through this week. Some Direct 3D are starting to work. I was able to play for a few minutes in Expendables (1999 DirectX 6 3D game) https://en.wikipedia.org/wiki/Millennium_Soldier:_Expendable So if the games your are interested in work with Wine then there is a chance Boxedwine will work, you should check back in a few months.
Reply 46 of 88, by Agathosdaimon
okay, i must profess again my ignorance -i never knew of this wine page - wine is still yes a program designed for running windows programs on apple computers yes? is wine something that can be used in windows already for trying to get old games working?
Reply 47 of 88, by Agathosdaimon
although not listed there - i would really like to know if maybe boxed wine could run iF-22 and or iF/a-18 - i think these 2 interactive magic games from the late 90s have been the challenge of the past decade for me. even Jane's F/a-18 has recently cracked when i have tried some more dxwnd approaches, but if-22 and if/a-18 remain impossible to get going (i think it may have to do with the movies which seem to have some coding issue running on windows 10
iM1-a2 abrams runs in windows 10 but it currently runs far too fast when it comes to projectiles flying and if the tank goes done a slope it goes into hyperdrive
if boxed wine could work for any of these iMagic sims, i would like to know
Reply 48 of 88, by danoon
There might be some hope. I tried iF 22 and it mostly worked. The movies would crash near the end of the movie, but eventually I was able to get to the main screen. I tried the instant action. It works, but it wasn't very responsive to my keyboard commands, it was hard to control. Maybe someday when I get joystick support it will be more playable.
    375.69 KiB
Reply 49 of 88, by Agathosdaimon
oh thats great, - my best effort was geting it to run with virtualbox win98se - but its sound is all broken and had game-breaking stuttering in the 3d parts - frustrating as other imagic games liek spearhead and im1a2 mostly work fine in oracle virtualbox
so now i just need to learn how does one actually use boxedwine - i dont know any command line stuff for it, is there a guide, or is boxed wine still not really ready for use?
Reply 50 of 88, by danoon
19R1 Beta 2 Release
Changes from 19R1 Beta 1
* Fixed bugs in the Windows 64-bit build
* Added support for SSE instructions, and bumped the CPU to be reported as a Pentium 3
* Enabled support for Direct 3D, this is experimental, so if you are lucky maybe 50% of the Direct 3D games you try will work. You should probably stick to games around the year 2000 or before.
https://sourceforge.net/projects/boxedwine/fi … 201%20Beta%202/
Reply 51 of 88, by danoon
You can try 19R1 Beta 2 that I just released. iF 22 is not a simple game to install. You will need to copy both CD's to a single directory, fs/home/files/if22/, for example. See HowToInstallYourOwnGame.txt in the new beta for a more detailed explanation. After you install it you will need to copy fs\home\files\if22\Data\*.* to fs\home\username\.wine\drive_c\I-Magic\F22\Data (the installer left some on the cd).
To make the UI look right you will need to set the resolution to 1024x768 instead of using the default 800x600, something like this
cd bin64
BoxedWine64.exe -resolution 1024x768 -root ../fs -zip ../fullWine1.7.55-v7.zip -w /home/username/.wine/drive_c/I-Magic/F22 /bin/wine if22
If it crashes at the end of each movie, next time just click the movie before the end so that it will be skipped.
Reply 53 of 88, by Serious Callers Only
Some wiine devs created a similar project recently using qemu (to run on ARM):
https://github.com/AndreRH/hangover/commits/master
virtualization unfortunately only would really help in x86 compatible cpus, not arm (among other problems). Slowness seems to be in the future of x86 on android or rpi anything (except if in a intel x86 cpu ofc)
Reply 54 of 88, by danoon
I'm also curious what will happen on Android/ARM. I think it wouldn't take too much to get Boxedwine to run on ARM without a recompiler. And a basic dynamic recompiler shouldn't be too hard either, I have a basic x86 dynamic recompiler (https://sourceforge.net/p/boxedwine/code/HEAD … /x32/x32CPU.cpp) that is only about 2000 lines of code. Boxedwine handles the dynamic parts generically and each CPU implementation only needs to handle a few micro ops. Of course a true multi-threaded x86 to ARM binary translator like I have for x64 would probably take a long time to create.
I will probably think more seriously about Android/ARM once Wine has a DirectX implementation for OpenGL ES.
Reply 55 of 88, by danoon
Just thought I would share an update and a screen shot.
OpenGL pass through is working pretty well with the x64 build. Here is Quake 3 with about 250fps.
    332.32 KiB
Reply 56 of 88, by danoon
This is an old version of World of Warcraft I had lying around on the hard drive, but it is also the newest game I got to work in Boxedwine. This is from 2010. I'm only seeing about 1 FPS, but I'm still pretty amazed it works.
    795.48 KiB
Reply 58 of 88, by danoon
I started working on a UI, here is what I have so far. It uses wxWidgets, so it should be able to work on multiple platforms. So far I have it building for Xcode (Mac) and MSVC (Windows).
    238.77 KiB
Reply 59 of 88, by danoon
Boxedwine19R1 (svn 966) https://sourceforge.net/projects/boxedwine/fi … %20Release%201/
Builds (all include Wine 1.7.55 and Wine 4.0)
* BoxedWine19R1.exe
Windows installer for 64-bit machines.
* BoxedWine19R1-32bit.exe
Windows installer for 32-bit machines, including Windows XP
* BoxedWine19R1.zip
Windows 32-bit and 64-bit binaries, no installer. You can download this if you just want the file systems to use if you make your own builds.
2019-09-18
Changes from 19R1 Beta 2
* Added new UI to manage games and containers for Windows and Mac builds
* Added Wine 4.0 file system
* Windows build can now integrate with the OS to launch 16-bit apps directly from Explorer (Container setting)
