First post, by aaronwhooley
Hello all,
I have recently taken my old awe 64 gold out of the cupboard and started tinkering with it.
All was running fine for about 1 hour, then the audio volume level dropped dramatically.
Then I tested the output of the card via SPIDIF and works ok, but on the analog line out I need to crank it up to the last just to hear a faint signal!
Would any of you guys have any ideas?, could it be capacitors?
Thanks in advance,
Aaron
PS I checked all the mixer settings and all seems to be normal
