First post, by okenido
Hello
I've fitted an E-ATX motherboard in my ATX case, all went fine but I lack like 0,5 inches space for the floppy drive. I can't put it completely in since it would hit a part of the Mobo.
Do you know if floppy drives that a a bit less deep do exist ? All the floppy drive I have seems of standard depth..
Reply 1 of 6, by Baoran
I went through all the floppy drives I have (the ones that are not inside of a pc right now). There are differences in length of the floppy drives I have but they are very minor. Longest is about 15.5cm and shortest is about 14.5cm.
Reply 2 of 6, by JidaiGeki
I thought the LS120 3.5" might be shorter, but it looks like it's the same as a normal floppy in length (15cm).
Manual with dimensions of drive - http://stuff.is-a-geek.net/OnlineDocs/Hardwar … /ls-120_IDE.pdf
Pics of internals of LS120 - http://goughlui.com/2013/05/02/tech-flashback … s-120-showdown/
As it has to accommodate a 3.5" disk that's 9cm long there's probably not a lot of wasted space in those drives. Guess you'll have to look at either USB external floppy or maybe a 5.25"/3.5" combo drive if your 5.25" bays aren't blocked as well?
Reply 3 of 6, by okenido
1.3 MiB
I have one spare drive I'll maybe try to cut the bottom left corner since this is unused space ^^
I want to put the drive in its 3,25 bay because it's integrated with the case (the case has the floppy drive button, left hole and slot)
Reply 4 of 6, by okenido
1.69 MiB
As u can see there is not much space left but I still have the 5" bays 😀
Currently the left back side of the floppy hits the cpu
Reply 5 of 6, by Tetrium
Newer floppy drives tended to be shorter.
If you can't get it to fit in a 3.5in drive bay, then you could just use a 3.5in to 5.25in adapter bracket so you can be done with this and get on with your build 😀
Another option could be to use a case that has more spare room at the front, depending on how well you are stocked on older compatible cases.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 6, by Errius
This is the problem with E-ATX cases. You carefully plan a build only to find that the parts you want won't fit in the case. Ugly kludges become necessary.
I had a similar problem with removable HDD enclosures in one of my systems.
Is this too much voodoo?
