First post, by Jo22
Hello everyone,
I'd like to ask you a favour..
Inspired by the unknown Compaq graphics hardware in this thread over here,
I did a few tests with the Olivetti 640x400x1 graphics mode.
It seems that Quick-Basic 4.5 does indeed support this mode.
Now I wonder how many PC systems were compatible to this CGA extension.
If you have some spare free time and don't know what to do with it,
please run that little QB program on your old CGA machine(s).
Perhaps we're lucky and some of them do support that mode inofficialy.
Or maybe not. Emulators, such as PC-Speed, ATonce, etc. are also welcome. 😀
Any feedback/comments welcome. You can also post some pictures, if you wish.
(Since this is a low-priority topic you may want to use external picture storage, too)
Video: http://youtu.be/k4B0Y7X3WHU
More information:
http://en.wikipedia.org/wiki/Olivetti_M24
http://en.wikipedia.org/wiki/Toshiba_T3100
http://www.youtube.com/watch?v=CsNngpf96Ro
http://www.computinghistory.org.uk/det/4587/Toshiba-T3100/
http://www.minuszerodegrees.net/manuals/Toshi … 20-%20Flyer.pdf
http://www.old-computers.com/museum/computer.asp?c=535
http://www.old-computers.com/museum/computer.asp?c=154
http://www.old-computers.com/museum/computer.asp?c=531
    m24.zip
    29 KiB
    140 downloads
    QB 4.5 "CIRCLE" sample program (slightly altered).
    Sets SCREEN 2 (CGA) and SCREEN 4 (Olivetti).
Reply 1 of 9, by Jo22
Update. I'm currently experimenting with the 640x400 monochrome mode again.
I've found some information regarding the structure of the video memory and its size.
You're still invited to join testing - any suggestions and ideas welcome as always. 😀
    25.48 KiB
    Diagram 640x400 memoy layout
Reply 2 of 9, by Jo22
Hi everyone, by the end of the last year, I started working on CGAView again.
Here's an experimental release that includes some improvements (hopefully) and support for the 640x400 mode.
It also supports crossloading so far, so you can, for example, display these hi-res pictures on normal CGAs, too.
Hope you enjoy! ^^
As usual, please feel free to share your opinions below.
    cviewx.zip
    384.07 KiB
    139 downloads
    CGAView X v0.3
    Experimental version.
    Adds M24/AT&T/Logabax 640x400 mode.
Reply 3 of 9, by ediflorianUS
Hi , I am ready to help test your files. I have Toshiba T3100e , and unable to start win (L.E. managed to start win2.03... work-in progress) and it seems that all EGA/VGA game requirements are out of my reach so... only CGA/Olivetti/AT&T remains.... Downloaded files now, will boot up system and give it a go.
L.E.
I can report that most of the things work ok on t3100e
last image did not load but that is about all.... (and of coarse no vga mode set with the set program)
My 80486-S i66 Project
Reply 4 of 9, by Jo22
ediflorianUS wrote on 2021-01-17, 09:41:
Hi , I am ready to help test your files. I have Toshiba T3100e , and unable to start win (L.E. managed to start win2.03... work- […]
L.E.
Thank you very much for your help! 🙂👍
PS: Sorry for the late reply, just noticed your posting!
Reply 5 of 9, by Plasma
FYI QB has a BIOS check before it allows SCREEN 4 to run. If you make this change to either QB.EXE/QBASIC.EXE or your compiled program, then 640x400 will work on "Super CGA" Compaq/Toshiba systems and DOSBox-X.
Reply 6 of 9, by Jo22
Plasma wrote on 2022-07-03, 05:03:
Thank you! ^^
Edit: Here they go.
    m24_fix.zip
    28.41 KiB
    73 downloads
    cviewx_fix.zip
    38.33 KiB
    76 downloads
Reply 7 of 9, by Jo22
Hi. There's a recent video about "Super CGA" graphics cards.
It also demonstrates the Olivetti 640x400 mode.
https://www.youtube.com/watch?v=xNsK_F4JlG4
Also interesting is this older one :
https://www.youtube.com/watch?v=mUCh46_MzZU
Reply 8 of 9, by Jo22
Quick update. I've noticed that CGAView X doesn't run properly in PC-Ditto emulator.
Maybe it's because the utility clears the screen during start and then sets plain text-mode.
- Which in turn might not be supported in CGA machine mode, if it's MDA-specific (there's a separate machine mode for MDA).
The updated utility now does use CGA's high-resolution graphics mode instead. I know, it's just a temporary fix.
I would have also rather done it right, but I'm a bit busy right now (life and things). Hope you don't mind.
Edited.
    4.37 KiB
    2.94 KiB
    cviewx_fix2.zip
    40.58 KiB
    11 downloads
    CGAView X v0.5; uses hires graphics mode for text, patched for generic AT&T graphics hw
Reply 9 of 9, by Jo22
Quick update. I just want to let you know that DOSBox-X has a support for Olivetti/AT&T graphics mode under the name of "DCGA".
https://dosbox-x.com/wiki/Guide%3AVideo-card- … E2%80%90X#_dcga
You select a VGA or VGAONLY machine setting in config file, start DOSBox-X and type DCGA at command line prompt.
That will turn the graphics system into an Olivetti/AT&T compatible mode. I've tested it with latest CGAView X, too.
I think the technical background for this implementation in DOSBox-X is very interesting.
In Japan of the mid-80s, the Toshiba J-3100 laptop had been released.
It was based on the existing 3100 series, which already had 400 line mode support.
More information: https://en.wikipedia.org/wiki/Toshiba_T3100
I can see parallels here to DOS/V (/V=VGA) of the early 90s here: DOS/V also had two select-able display modes.
On MS-DOS version, its very easy to do. Typing "US" will activate English mode, while "JP" will activate Japanese mode.
In a similar fashion, in DOSBox-X, VGA as a machine mode is now being used to provide a selection between
the new Japanese mode (DOS/V with VGA) and the old Japanese mode (J-3100 with DCGA).
    65.56 KiB
    sample picture
