Buran X3M : General MIDI Space Race
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: General MIDI Space Race -- Project X3M Polaris
Postby dreamblaster » 2018-7-06 @ 20:08
and optional tail :-)
Visit http://www.serdashop.com for retro sound cards, MIDI PCB's, and video converters
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects ! Have a look, and thanks for your support !
dreamblaster
Postby appiah4 » 2018-7-06 @ 23:50
Oh yeah my X3M is ready!
1989:A500|1M|ACA500+|C1084S
1992:HIPPO-VL+|U5SX-33|8M|GD5428|CT2290|S2
1995:P5I430VX|P133|32M|Trio64|V1|CT3980/32M
1998:S1573S|K6-2/400|64M|RagePro|V2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
2004:K8V-D|3700+|2G|X1950P|SB0350
User avatar
appiah4
Postby gdjacobs » 2018-7-07 @ 00:57
User avatar
gdjacobs
Postby dreamblaster » 2018-7-07 @ 05:18
dreamblaster
Postby dreamblaster » 2018-7-13 @ 19:00
Buran front view
Buran side
X3M side
Buran powered, some green LED glow at the boosters
Buran fully docked
dreamblaster
Postby keropi » 2018-7-13 @ 19:43
looks really nice, better than the original IMHO
User avatar
keropi
Postby dreamblaster » 2018-7-13 @ 20:12
oh, and it is 'brick' compatible :-)
dreamblaster
Postby dreamblaster » 2018-9-29 @ 11:29
nearing launch date !!
dreamblaster
Postby dreamblaster » 2018-9-30 @ 15:05
Anyone knows a large Russian youtuber that does midi or dos stuff ?
I hope to promote the Buran launch a bit...
The launch is on november 15th !! exact 30 years anniversary of the buran flight !
dreamblaster
Postby appiah4 » 2018-10-01 @ 22:27
Well, in celebration of X3M Buran's launch, enjoy some X3M GUD recordings.
https://soundcloud.com/user-470084971/s ... -soundbank
User avatar
appiah4
Postby dreamblaster » 2018-10-13 @ 16:06
a beta version of the Buran 0.9 GM bank is now available at http://serdaco.com/downloads/?dir=X2/X2 ... k/GM/BURAN
dreamblaster
Postby dreamblaster » 2018-10-13 @ 16:52
also created a hackaday page for it now : https://hackaday.io/project/161817-bura ... ynthesizer
dreamblaster
Postby moturimi1 » 2018-10-13 @ 17:55
dreamblaster wrote:a beta version of the Buran 0.9 GM bank is now available at http://serdaco.com/downloads/?dir=X2/X2 ... k/GM/BURAN
Thanks again for improving the Sound bank.
I tested the Buran 0.9 bank with the Intro of Dark Forces. Unfortunately I recognized a problem with the "synth brass 1". It sounds off maybe due to a too high volume.
Maybe you can improve it for the final release.
moturimi1
X3M Buran : General MIDI Space Race
Postby dreamblaster » 2018-10-13 @ 20:00
Maybe you can inprove it for the final release.
Thanks for testing, your feedback is very welcome
Is it a clipping problem you experience ?
synth brass 1 is indeed one of the new instruments, this was newly synthesized.
As you may know the preset determines the amplifier gain and equalizer settings.
Are you testing on an X2 with the default preset ?
Please let me know.
I will test in exactly the same setup, find a solution, and will report back ASAP
dreamblaster
Re: X3M Buran : General MIDI Space Race
Postby moturimi1 » 2018-10-14 @ 11:56
dreamblaster wrote:Thanks for testing, your feedback is very welcome
The volume seems to be wrong, no issues with clipping as far as I can say.
For the test I had to load a equalizer preset with less effects (Serdaco_LessIsMore) as my previous setting had too much chorus and reverb with the new soundbank.
Maybe you can tell us which instruments you changed so we can check the performance of these in some midi arrangements.
I reflashed the GUD 1.04 soundbank and I will stay with it for the moment.
moturimi1
Postby dreamblaster » 2018-10-14 @ 12:52
most instruments, while having smaller tweaks, are still based on general user.
These synth intstruments are new, generated from scratch :
38-Synth Bass 1 (MOD)
50-Synth Strings 1 (MOD)
51-Synth Strings 2 (MOD)
62-Synth Brass 1 (MOD)
63-Synth Brass 2 (MOD)
80-Square Lead (MOD)
81-Saw Lead (MOD)
If the problem is only the volume/balance, I will try to change the balance to better suit the games.
The overall goal is to achieve the same balance as SC-55, but with its own sound characteristic
If in some cases the GUD instrument is preferred above the new synthesized, I can revert to that as well, of course
I agree the default setting has quite some reverb/chorus, this is also the case in X3MB.
I will try to provide a buran preset, but the optimal preset is depending on taste as well.
In general the more 'dry' presets were not received so positively
dreamblaster
Re: Buran X3M : General MIDI Space Race
Postby matze79 » 2018-10-24 @ 13:08
Had time today to try it out :)
i recorded 3 Games:
https://soundcloud.com/matthias-werner- ... release-09
Doom sounds really good! :)
Monkey Island sounds eeehm intressenting :D
i need to figure out howto disable the hall effect :)
@Dosreloaded.de:
https://dosreloaded.de/forum/index.php/ ... rerelease/
https://www.retroianer.de
matze79
Postby keropi » 2018-10-24 @ 16:36
is monkey island running in GM mode? the original is only Roland so thid explains the weird music
Ultimate Talkie DOS patch allows for GM soundtrack
User avatar
keropi
Postby Phreeze » 2018-10-25 @ 08:22
Monkey Island is always sounding weird, if not used in MT32 mode with a real Mt32. I get also weird sound when i use only the SC55. MI is overly attached to the Mt32 ^^ :kiss:
ArGUS Parts list: http://bit.ly/2Ddf89V
User avatar
Phreeze
Postby appiah4 » 2018-10-25 @ 23:39
Monkey Island in MIDI (Ultimate Talkie) sounds fine. Here are some recordings for your :cool:
Doom E1M1 At Doom's Gate: https://soundcloud.com/user-470084971/d ... oms-gate-3
Monkey Island (Ultimate Talkie) Intro: https://soundcloud.com/user-470084971/m ... main-theme
User avatar
appiah4
PreviousNext
Return to Sound
Who is online
Users browsing this forum: No registered users and 2 guests
