Reply 20 of 49, by dreamblaster
and optional tail 😀
    422.39 KiB
    885.77 KiB
    772.8 KiB
Thanks for your support !
Reply 23 of 49, by dreamblaster
https://youtu.be/IR5CfqrsbrA
Reply 24 of 49, by dreamblaster
Buran front view
76.59 KiB
Buran side
92.45 KiB
X3M side
126.21 KiB
Buran powered, some green LED glow at the boosters
130.87 KiB
Buran fully docked
106.91 KiB
Reply 26 of 49, by dreamblaster
oh, and it is 'brick' compatible 😀
81.77 KiB
Reply 27 of 49, by dreamblaster
nearing launch date !!
Reply 28 of 49, by dreamblaster
Anyone knows a large Russian youtuber that does midi or dos stuff ?
I hope to promote the Buran launch a bit...
The launch is on november 15th !! exact 30 years anniversary of the buran flight !
Reply 29 of 49, by appiah4
Well, in celebration of X3M Buran's launch, enjoy some X3M GUD recordings.
https://soundcloud.com/user-470084971/sets/dr … d-104-soundbank
Reply 30 of 49, by dreamblaster
a beta version of the Buran 0.9 GM bank is now available at http://serdaco.com/downloads/?dir=X2/X2_Sound … nkPack/GM/BURAN
Reply 31 of 49, by dreamblaster
also created a hackaday page for it now : https://hackaday.io/project/161817-buran-gene … idi-synthesizer
Reply 32 of 49, by moturimi1
Thanks again for improving the Sound bank.
I tested the Buran 0.9 bank with the Intro of Dark Forces. Unfortunately I recognized a problem with the "synth brass 1". It sounds off maybe due to a too high volume.
Maybe you can improve it for the final release.
Reply 33 of 49, by dreamblaster
moturimi1 wrote:
Thanks again for improving the Sound bank. I tested the Buran 0.9 bank with the Intro of Dark Forces. Unfortunately I recognized […]
Maybe you can inprove it for the final release.
Thanks for testing, your feedback is very welcome
Is it a clipping problem you experience ?
synth brass 1 is indeed one of the new instruments, this was newly synthesized.
As you may know the preset determines the amplifier gain and equalizer settings.
Are you testing on an X2 with the default preset ?
Please let me know.
I will test in exactly the same setup, find a solution, and will report back ASAP
Reply 34 of 49, by moturimi1
dreamblaster wrote:
Thanks for testing, your feedback is very welcome Is it a clipping problem you experience ? […]
The volume seems to be wrong, no issues with clipping as far as I can say.
For the test I had to load a equalizer preset with less effects (Serdaco_LessIsMore) as my previous setting had too much chorus and reverb with the new soundbank.
Maybe you can tell us which instruments you changed so we can check the performance of these in some midi arrangements.
I reflashed the GUD 1.04 soundbank and I will stay with it for the moment.
Reply 35 of 49, by dreamblaster
moturimi1 wrote:
The volume seems to be wrong, no issues with clipping as far as I can say. For the test I had to load a equalizer preset with le […]
most instruments, while having smaller tweaks, are still based on general user.
These synth intstruments are new, generated from scratch :
38-Synth Bass 1 (MOD)
50-Synth Strings 1 (MOD)
51-Synth Strings 2 (MOD)
62-Synth Brass 1 (MOD)
63-Synth Brass 2 (MOD)
80-Square Lead (MOD)
81-Saw Lead (MOD)
If the problem is only the volume/balance, I will try to change the balance to better suit the games.
The overall goal is to achieve the same balance as SC-55, but with its own sound characteristic
If in some cases the GUD instrument is preferred above the new synthesized, I can revert to that as well, of course
I agree the default setting has quite some reverb/chorus, this is also the case in X3MB.
I will try to provide a buran preset, but the optimal preset is depending on taste as well.
In general the more 'dry' presets were not received so positively
Reply 36 of 49, by matze79
Had time today to try it out 😀
i recorded 3 Games:
https://soundcloud.com/matthias-werner-matze/ … m-prerelease-09
Doom sounds really good! 😀
Monkey Island sounds eeehm intressenting 😁
i need to figure out howto disable the hall effect 😀
Reply 37 of 49, by keropi
is monkey island running in GM mode? the original is only Roland so thid explains the weird music
Ultimate Talkie DOS patch allows for GM soundtrack
Reply 38 of 49, by Phreeze
Monkey Island is always sounding weird, if not used in MT32 mode with a real Mt32. I get also weird sound when i use only the SC55. MI is overly attached to the Mt32 ^^ 😘
ArGUS Parts list: http://bit.ly/2Ddf89V
Reply 39 of 49, by appiah4
Monkey Island in MIDI (Ultimate Talkie) sounds fine. Here are some recordings for your 😎
Doom E1M1 At Doom's Gate: https://soundcloud.com/user-470084971/doom-e1 … at-dooms-gate-3
Monkey Island (Ultimate Talkie) Intro: https://soundcloud.com/user-470084971/monkey- … lkie-main-theme
