First post, by IMeganElisabeth
I’m wanting to try implementing PowerStrip in my VM with virtual box to increase resolution to a custom setting. I currently have Digital Doctor installed and fixed at its maximum of 1600x1200 successfully. I’m wondering how exactly I need to go about trying PowerStrip without messing up my VM (I REALLY do not want to have to reinstall Windows - or would it worst case scenario boot in safe mood if the resolution or switch between these two applications somehow messed it up?) This is the first VM I’ve ever created. I want to do this as safely as possible. So, do I need to remove digital doctor first and then download PowerStrip and try it or could I just try it on top of digital Doctor or somehow disable it and revert back to original graphics within digital Doctor? Am open to any and all suggestions to try this switch without messing up Windows. Thank you so much in advance!
