How about a MR-BIOS ROM file repository?
Reply 520 of 557, by douglar
TheMobRules wrote on 2026-02-14, 02:02:
douglar wrote on 2026-02-14, 00:27:
I was using the default settings. Any idea what I might be able to tweak?
You need to short pins 16-17 on the front panel header. It seems this MR BIOS defaults turbo speed to low.
That did the trick for me.
The attachment TURBO_result.png is no longer available
Here's how it looked after setting 2111 cache timing and 0 wait state:
The attachment 2111-1_result.png is no longer available
I get some great results using the sis.exe tool, but things are not stable. I can try some other Simms.
Are there any memory setting that are recommended?
The attachment MemorySettings.jpg is no longer available
I also noticed this when using a Promise IDE 20630 controller--
The attachment Promise 20630.png is no longer available
Benchmarks were about 6300KB/s read and write using the auto transfer rate, so it was doing something.
edit -- Looks like the rom also detects Appian ADI2-VL, OPTi 611-VL, & CMD 640B-VL
Reply 521 of 557, by appiah4
Why doesn't it work on my board.. Why! 🙁
Reply 522 of 557, by GigAHerZ
appiah4 wrote on 2026-02-23, 05:59:
There were SIS471 "green" and "non-green" variants or something. Basically, when you scroll through motherboards in retroweb with SIS471 chipset, they all have in bios strings either a single letter in addition to SIS471, or a bunch of letters after it. But they don't overlap.
Therefore i have concluded there were 2 variants of SIS471 chipsets.
The MR BIOS shared here shows "BIOS ID" as "SIS_41G". So it's probably for the "green" variant.
A little about software engineering: https://byteaether.github.io/
Reply 523 of 557, by megatog615
Check if your board has the same SuperIO chip as well.
Reply 524 of 557, by TheMobRules
douglar wrote on 2026-02-22, 18:55:
What kind of instability are you experiencing? I'll try to replicate on my side.
Set Write Delay to Early, it will give a considerable boost to the write speed.
Reply 525 of 557, by appiah4
My board is the Chicony CH-471A v3.0 https://theretroweb.com/motherboards/s/chicon … h-471a-ver.-3.0
SiS 85C471
SiS 85C407
I only get a black screen when I POST with this BIOS. When I verify the EPROM in a reader, it validates fine. I am reluctant to waste another EPROM because I don't have an eraser and need to put it in the sun and let it wait for 3-4 months 😁
GigAHerZ wrote on 2026-02-23, 10:56:
There were SIS471 "green" and "non-green" variants or something. Basically, when you scroll through motherboards in retroweb wit […]
I wonder how I can check mine? I wonder if they have any markings to tell them apart. I have the Award BIOS on the board dumped, maybe looking at that could help.
EDIT: A thought just occured to me: Maybe this BIOS does not work with UMC U5S processors? That's what I have in the board currently and tested with only that. If anyone else can test their boards with a UMC CPU to confirm it works, I'd be glad.
Reply 526 of 557, by GigAHerZ
appiah4 wrote on 2026-02-24, 07:11:
I'm afraid the "A" vs "G" is the defining indicator.
I have this board: https://theretroweb.com/motherboards/s/qdi-v4s471-g
Here's also another board with updated bios for L2 cache fix: https://theretroweb.com/motherboards/s/asus-vl-i-486sv2gx4
And i remember that on my board, the "A" BIOSes either didn't boot at all or hanged during very first moments of POST. All "G" board bioses worked well. (As a result, the bios with "write-back L2 cache" on Asus and the "EFA bios that works" on QDI are bioses submitted by me)
On the QDI's board bios list, the EFA bios that i found, notice the BIOS string: "85C471B/E/G" - no "A", but has everything else. From this i conclude there are basically 2 variants (in practice) of SIS471.
Reply 527 of 557, by appiah4
The BIOS string from mine is 01/18/95-SIS-85C471B/E/G-2C4I9C21-00 So I don't know what to make of that. The board just does not POST with the MR BIOS.
Here is the BIOS from my CH-471A V3.0 in case anyone wants to submit to theretroweb.com I really don't want the hassle of going through their Discord 😁
Reply 528 of 557, by GigAHerZ
Okay, it now got a lot more confusing and my theory does not hold water any more...
Reply 529 of 557, by weedeewee
appiah4 wrote on 2026-02-24, 18:27:
submitted on their discord hassle 😉
https://discord.com/channels/7131124000599572 … 953445130338632
edit: also, for some reason on https://theretroweb.com/motherboards/s/chicon … h-471a-ver.-3.0
it indicates 1 file for bios but none is available.
Do not ask Why !
Reply 530 of 557, by megatog615
Discord is preferred but you can send an email. Their email address is at the bottom of the page.
By the way, are you using a POST card?
Reply 531 of 557, by douglar
weedeewee wrote on 2026-02-24, 20:32:
That's strange right? A stub for a bios entry was created but never populated with any info or file. It's fixed now that your BIOS info was added to the stub.
You should try a post card with your board. MR Bios post codes are on page 102.
https://drivers.dosreloaded.de/Books/The%20BI … OST%20Codes.pdf
Reply 532 of 557, by weedeewee
douglar wrote on 2026-02-25, 02:11:
That's strange right? A stub for a bios entry was created but never populated with any info or file. It's fixed now that your […]
It's appiah4's bios, and whomever added it didn't checkmark the discord entry.
edit: oh, so you added it 😀
checked the logs.
I did notice that there was an entry on the v1.0 board revision that had the same bios string.
Do not ask Why !
Reply 533 of 557, by appiah4
megatog615 wrote on 2026-02-24, 22:45:
I am using a POST card, I get no POST codes. I don't recall if the IRDA light goes on though, but IIRC it does not 🙁
Things I haven't tried:
-Try with an Intel CPU
-Try a second EPROM
Maybe this weekend I'll get to try those.
Reply 534 of 557, by lsorense
That did the trick for me. […]
That's neat. It never offered any IDE settings on my QD6580 card. I always wondered what it was talking about for speed settings.
Reply 535 of 557, by rjbrown99
Hi, so I have a Gigabyte GA-486VF, which is based on SiS 85C471/407. https://theretroweb.com/motherboards/s/gigabyte-ga-486vf
I tried the MR BIOS for it (mrbios-sis471-v3-21.zip) but it's not working properly. I can enter the BIOS and configure all of the options, but my Buslogic BT-445 throws a "HOST ADAPTER CMD PROTOCOL FAILED". This was confusing for a while and changing card settings and addresses had no impact, nor did toggling a ton of options in the BIOS itself (cache off, shadowing off, different VLB settings, etc). So I moved to an Adaptec AHA-2842A, which did get as far as the DOS boot menu but hangs as soon as you select an option.
After reviewing the MR BIOS documentation, it looks like there were multiple versions for different boards, and one main differentiator was the number of RAM slots. The BIOS I used from the forum here appears to be from a board with 4 RAM slots, while my board has 8 slots. The MR BIOS inventory seems to indicate that part number V089B415 OR V089B412 would be the correct one to use when you have 8 memory banks. And of course those have also been lost to time until someone finds it.
So I believe I'm out of luck for now. Unless I'm not understanding their inventory correctly (see attached).
Reply 536 of 557, by megatog615
Anyone know if there's a MR BIOS rom building program like cbrom or amibcp to create a rom file with option roms? Or does MR BIOS not care and just let you concatenate files into one big binary rom?
Reply 537 of 557, by Anonymous Coward
rjbrown99 wrote on 2026-05-31, 00:46:
I assume you must have eight 30-pin RAM slots. In this case, you have two memory banks (not eight). That would be equivalent to having two 72-pin RAM slots.
Reply 538 of 557, by Babasha
Mr.BIOS 3.43 for DEC DECpc LPV (LPV+)
-no HDD limitation
-no Y2K RTC/BIOS error
-no 36bit SIMMs required (it works with usual FPM modules)
-fast, customizable and beauty at all)))
Need help? Begin with photo and model of your hardware 😉
Reply 539 of 557, by Babasha
megatog615 wrote on 2026-05-31, 03:07:
You can concate it but in right order and size of BIOS extensions
