First post, by john11139
Please bare with me as at my age I don't quite understand what I read. I need a little help. I have three programs that I have run on all my different computers, Even before windows 3.1 was available. Old DOS programs. I cant find any programs as simple to use and run as these, so I( have stuck with them over the years. (although I am sure newer programs are available that would work also) These programs have my tax, real estate, payroll records from 25 years ago. Every time I bought a new computer I would have 32 byte installed. up through Windows 7. I recently bought a new computer with Windows 10 and was told that 32 byte could be installed on it, but that is not true because no drivers are available for it. (The programs are Professional Write, Professional Plan and one called The simple book keeper) I had a student load my computer with the DOS box. I got my programs loaded and they work. But here is not what I can't figure out. I want to make a directory called "Apex" and every thing under that. (Prof plan, Prof Write) And then one under Apex called "Expense". So that under Apex I don't have 25 files showing up, ( Exp 1988 , Exp 1989 through Exp 2016 etc) When I try and make a directory with those names, it says "not a executable file." I know how to get into c: drive and also my DOS drive "Z" Can someone please walk me through this. Thanks
