Reply 20 of 47, by The Serpent Rider
the only material damages I can see are the missing SMD component (labeled R143JNB89, but googling this gives me nada, so if anyone can tell me what exactly I need to replace this with I would be grateful
As I've said before - standard 14.318 mhz crystal oscillator.
Reply 21 of 47, by appiah4
Thank you I have ordered a dozen 😀
Reply 23 of 47, by appiah4
mzry wrote:
Yeah you got there pretty much the best V3 worth owning, hope you bring it to life!
So do I, fingers crossed. I also changed the cooler I ordered for this card to the below:
1-Pieces-Aluminium-Heatsink-Cooler-40x10mm-Fan-For-PC-Computer-Northbridge-Chipset-Cooling.jpg_200x200.jpg
The other coller, with the fan on top, was 50mm high, and with the GPU die etc added that 55mm would have blocked off 3 PCI slots. This one is only 45mm high and should block only two slots (one of which is shared with the AGP slot anyhow). With active cooling 183MHz should be achievable 😁
Reply 24 of 47, by vvbee
I'd go for a large flat heatsink at the back piping as well as can from whichever components get hot and integrate cpu and gpu cooling with a funnel or two. Though I'd also underclock it and negate much of the need.
Reply 25 of 47, by -Maverick-
This reminds me of something similar I did back in the early 2000's with a Zalman cooler.
http://dbzer.net/3dfx/Voodoo_3_3000_PCI_01.jpg
http://dbzer.net/3dfx/Voodoo_3_3000_PCI_02.jpg
http://dbzer.net/3dfx/Voodoo_3_3000_PCI_03.jpg
http://dbzer.net/3dfx/Voodoo_3_3000_PCI_04.jpg
If anyone was around during the glory days of Voodoofiles, you might have stumbled across the forum thread.
edit: fixed linkes, my mistake. added attachments just in case.
Reply 26 of 47, by appiah4
Right.. so.. All the components arrived in the mail last week, so the first order of business was to get the crystal oscillater soldered onto the PCB (please let me know whether my assumption that this has no polarity is true or not..)
Next, I applied a generous amount of thermal paste onto the graphics chip.
Then I mounted the chipset cooler onto the card and if I may say so, it looks pretty good..
It covers the adjacent PCI slot and the one underneath, but it should cool pretty effectively. I will definitely try pushing this card to 3500 speeds as soon as I have time to test it in a system. 😎
Reply 27 of 47, by Fusion
Nah, push it higher then that! 😀
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
Reply 28 of 47, by appiah4
I've run into another problem, this card has one more missing SMD component. I've marked it with red in the attached picture. Can anyone who has access to a working Voodoo 3 3000 tell me what that component is supposed to be? Capacitor? Resistor? Rating? I need to source one and solder it onto the board before trying the card.
Reply 29 of 47, by Aideka
I do not own such a card, but my guess would be an inductor with the same values as the component L9 on the board.
Reply 30 of 47, by appiah4
How can I determine the rating of the inductor on L9?
Reply 31 of 47, by SSTV2
Don't worry too much about it, it's just a part of a LC low pass filter for one of the VGA signals. You can borrow such inductor from any dead video card or motherboard, its parameters are not critical.
Reply 32 of 47, by appiah4
I dont really have anything Im willing to scavenge for this.. what would be a likely fitting component here? 0402 I presume? What inductance?
Reply 34 of 47, by appiah4
SSTV2 wrote:
appiah4 wrote:
What inductance?
68 or 82 nH should do fine.
Many thanks; is it better to go for higher inductance when in doubt as one would for capacitors?
Reply 35 of 47, by appiah4
SSTV2 wrote:
appiah4 wrote:
What inductance?
My inductors came in, but I made an oops and got 82uH 0805 inductors 🙁
I can find 47nH 0603 or 150nH 0805 inductors locally, would either of these work?
Reply 37 of 47, by appiah4
stamasd wrote:
I would try the 47nH.
I ordered 50 82nH 0805s from Aliexpress.. another month of waiting before I am finished with this project *le sigh*
Reply 38 of 47, by stamasd
While you wait it's still worth trying the 47, can't hurt. 0603 should fit into a 0805 footprint.,
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 39 of 47, by appiah4
The inductor is done, but more roadblocks. The card has EVEN MORE pissing components.
R8: A zero ohm link by the looks of it, I can probably just jumper-wire this across.
157.37 KiB
CR10: An SMD Diode? I'm guessing it is an SMA S1G from what I can read (which should make it a 400V 1A Diode?)
189.62 KiB
C100:No definite information on what this is but I am almost certain it is 0.1uF 16V 0603, this is the rating I've found RAM capacitors to be on pretty much every Voodoo card I have.
113.83 KiB
I will put YET ANOTHER order for these parts..
The more I look at this card the more it looks like things have been HARVESTED from it, so I may end up with a non-working card in the end regardless 🙁 This has taken WAY longer than I thought it would but if it works in the end it will be hilarious and magnificent at the same time.
