First post, by Nic-93
Hey all, i hope its not a problem on asking about help on this pc emulater
i do have made sure to prepair for it to have sound blaster installed, but i keep getting this stupid error message, i cant figure out the trouble at all.
anyone figured a way to fix it?
    137.38 KiB
    The problem itself
    131.36 KiB
    default setting, noting changed.
    130.17 KiB
    type of computer
    130.88 KiB
    showing that i have the correct card set to it.
Reply 1 of 3, by Jo22
Hmm.. Not sure, but did you already try to see what happens if you uncheck the CMS/Game Blaster option ?
DOSBox, for example, has/had its OPL and SBType mode shared with the CMS.
Or in other words, it couldn't emulate both devices at the same time.
On real hardware, a SB 1.x/2.x card could provide both CMS and DAC/OPL2 comaptibility simultanously.
