Reply 20 of 39, by OldCat
candle_86 wrote:
shame your not local, ive got an amber hercules display sitting in my closet doing nothing
Pity! I've even checked the shipment cost to Poland to see if I could actually afford that, but sadly it's exorbitant.
What's ironic is that I've actually been to Fort Worth a couple of times when I was working with my previous employer (Stockyard, White Elephant Saloon and all that).
Reply 21 of 39, by candle_86
well if you find yourself back this way let me know
Reply 22 of 39, by OldCat
I think I owe everyone involved in this thread a bit of an update.
In short - I am going to hijack my own thread. You see, while this box and its components are very pretty, it is also very large. And one of my problems and the reason for unending quarrels on retro computers with my wife is the lack of physical space to keep them. While searching for Hercules-compatible amber monitor I have found something that let me kill three birds with one stone: Tandon CSP1622. It is a sort of all-in-one, AT with Hercules and compatible screen. Instead of having huge box with small Hercules monitor I have computer and display combined in a relatively small package. Naturally, I had to go for it!
Adios, Vobis AT. Hello Tandon AT.
Seller's photo:
346.75 KiB
It has arrived! CMOS battery dead, so dismantling the thing to see what's inside:
216.79 KiB
First success - setting disc type in BIOS. Drive operational, some German software still in place:
245.71 KiB
TBC
Reply 23 of 39, by Jo22
In short - I am going to hijack my own thread. [
Hah, that's cool. 😁 I'll have to remember to do this more often, too. 😉
Anyway, that 286 looks interesting to me. Reminde me a bit of the "Ergo" PC,
an 8088-PC that was built into a TTL/Mono CRT and had an ergonomic stand,
which the monitor/PC unit was mounted to and which could be moved in several dimensions.
I'm sorry, it's hard to describe. saw that PC once in my life in an old magazine.
Here's a drawing I made, maybe it gives an impression of the machine.
2.04 KiB
The monitor was a green TTL monitor, likely in 720x350 resolution.
Not sure if it had Hercules (aka MGA, HGC) already or in IBM fashion, MDA.
When I was little, when I had my multimedia 286 PC with 4MB RAM, VGA, PAS16, HP LaserJet and a handy scanner,
I had no clue that a "boring typewriter PC" could draw such beautiful monochrome graphics.
Just recently, I few years ago, Hercules got my attention again. Probably because of DOSBox and the fact that
my father did a few scans in the 1980 with its handy scanner. And since the picture program did save screen dumps
instead of using a proper picture format, these scans could only be displayed by using Hercules hardware.
That's when I started to learn about Hercules and monochrome graphics in general, I think.
If you like, also have a look at EMÚ386. It'll emulate some of the 386 real-mode instructions,
so you'll be able to run quite a few more programs on your 286. According to the manual,
this comes in handy for ISA PnP utilities, as required for the newer Sound Blasters (SB16 PnP, AWE series).
It may also work with other programs, such as games, provided that they are dumb and don't check for a 386.
Reply 24 of 39, by root42
Wow, GS-Menü brings back some memories... That software company made shareware software for small offices. Bookkeeping and such, as well as other tools, as this menu software.
YouTube and Bonus
Reply 25 of 39, by OldCat
I believe Herr Gandke's company is still active in the IT field (digital marketing agency, if I am not mistaken).
Well put. Nostalgia is a factor, granted, but there is elegance in high-resolution monochrome graphics. I will add some screenshot(s) later in this thread.
Could I ask if you are, by any chance, able to program DOS executables with Hercules mode graphics?
Reply 26 of 39, by OldCat
The second success - replacing hard drive with Compact Flash card and CF adapter:
180.34 KiB
Putting the adapter in one of the extensions slots required extending 0 and +5V cables, as well as finding long enough IDE cable (old type):
294.65 KiB
I have actually soldered power cable to the adapter, it came out rather nicely:
128.72 KiB
This is the third success - works with new power cable and IDE cable:
219.01 KiB
TBC
Reply 27 of 39, by Scali
I could help with that. I have made some helper functions in C and assembly to set the two Hercules modes (text and graphics), and tweak various things.
One of my experiments was to set up the Hercules memory to have 4 separate framebuffers, and flip between them.
By preprocessing a grayscale image into 4 buffers, I could simulate various levels of brightness by exploiting the afterglow of a monochrome monitor (basically a form of PWM).
Reply 28 of 39, by OldCat
After first couple of successes there came time for inevitable failure ("HOW QUICKLY THE TIDE TURNS"). NiCd accumulator that was fine when I first opened the PC vomited acid all over the board:
243.33 KiB
As it turns out, this is typical behaviour for NiCd accus that were not used for a long time and then got charged. Good thing I caught it relatively quickly, disassembled, desoldered accumulator and cleaned board so no damage done:
247.75 KiB
Reassembled it to check if it works and it did:
333.62 KiB
Then I went on to work on replacement. Unfortunately, this accumulator was a bit specific, so no off the shelf component would fit. I have asked a small company to build for me a custom one from button cells. Took them a while, but the result was spot on (dimensions, voltage, connections). Soldered it in:
235.29 KiB
...and once again the whole thing worked:
238.1 KiB
Fourth success! For some of you, this might be trivial, but for me these were the most advanced changes I ever did on a vintage machine.
TBC
Reply 29 of 39, by Jo22
Cool, thanks. I'm looking forward to it. Both CGA and Hercules remind me of the Gameboy, by the way:
Firstly in terms of Nostalgia (both are 80s tech) and secondly, because they share artistic aspects.
Gameboy had 4 shades, CGA has 4 colours. Hercules is black/white and uses dithering from time to time.
Well, yes, I am. By far not as much as Scali, however. He's from the demos cene and knows a lot about the internals.
To give an idea, just read what he wrote about the structure of Hercules video memory and you'll see.
Anyway, here's a little bit of something that I recycled from CGAView (not to be confused with a video player of the same name).
In essence, it's just a tool that lets you create and load Hercules screen dumps.
    184.92 KiB
    mgaview_test.zip
    261.9 KiB
    95 downloads
    https://youtu.be/pKCphBy2jGg
Reply 30 of 39, by OldCat
Spot on. I also really, really like Game Boy and its graphics. I have one with screen mod (backlight plus bivert):
86.26 KiB
I also happen to have two plasma screen Toshibas and like to compare how things look in pure monochrome and four shades of orange:
Metal Mutant compared on plasma screens of Toshiba T3100e (CGA) and Toshiba T5100 (CGA/EGA)
Jo22 wrote:
Well, yes, I am. By far not as much as Scali, however. He's from the demos scene and knows a lot about the internals.
Superb! I'll fire a private message your way to explain why I asked.
I will definitely give it a try. Quick question, as I will only be able to test it mid-next week at the very earliest - can you export these dumps to something readable / decipherable by modern software? Such as gif, png or bmp?
Reply 31 of 39, by OldCat
With accumulator repaired and HDD replaced by CF card, I thought all I needed was to reassemble the whole thing. I was naive.
I started playing with old games and discovered that image goes all haywire on some of them:
233.08 KiB
Ugh (not the game, just general sigh of disappointment).
Fortunately, fellow Vogoner 133MHz suggested a solution:
133MHz wrote:
That looks like the card is putting out 60Hz vertical frequency when running those games and the monitor is only syncing to the standard 50Hz for MDA/Hercules. A quick tweak of the V.HOLD control should sort it out, but if your monitor doesn't expose said control to the outside you'll have to open it up and look for it on the circuit board to adjust it while looking at the screen. You can find a balance where it will work on both 50 and 60Hz so you don't have to fiddle with it anymore.
I had never meddled with the insides of monitors before, so I was a little nervous. Took me a while to open the monitor case, but finally did:
139.08 KiB
Armed with thick non-conductive gloves, started looking inside and prodding various elements. The potentiometers weren't really in the most comfortable spot:
184.39 KiB
Nevertheless, I played with V.HOLD a bit, as 133MHz instructed me to do, and - lo and behold! - it worked:
211.31 KiB
TBC
Reply 32 of 39, by OldCat
The last part was re-assembling the whole thing: monitor covers, motherboard and power supply etc. A bit problematic, because I disassembled parts of it weeks ago - but having bumped into this problem before, I already am taking a lot of photos in the process. Apart from one small mistake, namely connecting HDD diode and power diode to wrong sources (whoever thought that green diode should have a red cable and vice versa was a moron... or had really dry sense of humour), it all went well:
179.07 KiB
As you can see, right now I am mostly playing old computer games on it - but I am not ashamed of it in the slightest, on the contrary, I love seeing these titles in childhood embers' colours again.
574.85 KiB
Mission accomplished.
Reply 33 of 39, by Jo22
Wow, this looks really great! You did a good job at restoring the computer.
The outcome of your restauration is really good! 😀 A Genius GM-6 mouse would fit to that, I think.
I also like the amber pictures of Bubble Bobble and Targhan, by the way.
I imagine, the expereince would be awesome (as in very 80s) if you could later add
a GameBlaster or Tandy 3-Voice card for music (for Bubble Bobble, at least).
Thanks for the photo! I abolutely loved that game, btw. Along with Wario Land 1 it was one of my favorites.
Yes, I think I can manage that. It'll take a bit, though. I have to read the specs about them first.
Also, if you only want to edit/display existing binary images of Hercules/CGA, you can run these viewers in DOSBox
and use the screen capture feature (Ctrl-F5). 😉
Hah, yes, indeed! Somehow I really hope it was a dry sense of humour! 😁
Reply 34 of 39, by Jo22
By the way, you can also play C64 IF games on your Amber 286..
The emulator programme is called c64 and supports Hercules.
Colours are dithered, which looks really nice sometimes! 😀
(Samples: *I was using my OTI-037C in MGA mode, since my 286 PC
w/ Hercules graphics and TTL-monitor didn't like it. Maybe it uses a custom resolution.)
    2.75 KiB
    C64 BASIC V2
    1.75 MiB
    Showing a directory listing/displaying the 1541 floppy index
    1.7 MiB
    Playing Leather Goddesses of Phobos
    1.61 MiB
    Playing a random text-adventure (MGA emulation)
    4.39 KiB
    Playing a random text-adventure (DOSBox: Hercules machine mode)
Reply 35 of 39, by OldCat
Hey Jo, thanks for your comments. Sorry, I couldn't reply earlier.
Jo22 wrote:
Wow, this looks really great! You did a good job at restoring the computer. The outcome of your restauration is really good! :) […]
I have a very similar Logitech mouse (and a holder!), but it hasn't yellowed at all and therefore doesn't fit this computer aesthetically (didn't think I'd ever use this phrase). If I see Genius GM-6 mouse, I will buy it, though, it's so retro.
GameBlaster and Tandy 3-voice would be a welcome addition, but they are unfortunately quite rare and very expensive. I've paid around 50EUR for the machine, about 20EUR for the keyboard and maybe 20EUR for the parts (cables, CF card, adapter, custom battery), so no more than 100USD altogether. I'm afraid PC Speaker will have to do for now, but on a positive side - it's very 80s as well.
Same here: second Mario Land and first Wario Land were totally the best games on the original Game Boy, transcending hardware limitations. I also really liked Contra: Alien Wars and Legend of Zelda. Last year discovered joys of using flash carts, so when I have some more time, I will check some hidden gems.
Wow, I didn't know that, but it's amazing. I will definitely give it a try. Might need to check if any other 8-bit computers would not be available as well. Thanks for the heads up.
Reply 36 of 39, by Jo22
No problem, same here. 😀
Ah, I see. That Logitech mouse is fine, too. It's just that I have little knowledge about vintage mice.
For some reason, the Genius GM models do pop up more often on fleamarkets and my country's eBay. 😕
This makes senes. 8-Bit cards themselves are rare now (in comparison). Gratefully, most 16-Bit cards do work, as well.
By the way, I once had a GameBlaster.. Naive as I was, I sold it on eBay. Because it seemed broken to me (no Win98 drivers). 😊
To my defence, I had no internet access and no idea what a GameBlaster was. I thought it was some sort of SoundBlaster clone.
If you like to enhance sound on your 286, you can install a Covox plug (or clone). Some of the classic games from the late 80s/early 90s
do support it. SimAnt, for example. The higher processing power of a 286 CPU is really helpful here.
If you wish, you can even combine the covox plug with some 80s audio systems (vintage stereo, ghettoblaster, etc.).
DSS / Covox Speech Thing exclusive games
That's cool. I missed Zelda at the time, but had the joy to played it later on in my teens.
GB games I also liked when I was little were Space Invaders, Kirby's Dreamland, Paper Boy (at a friends house),
Tiny Toons. For some reason, I muissed the whole Pokémon stuff everyone was crazy about.
I finally got into the series because of my little sister, when she found a Pokémon Emerald cartrige at the schoolyard..
That was the time when I took heart and got us a bunch of the classic GB carts of Red/Blue/Yellow
(all second-hand, I replaced some batteries, too. I had to buy a Tri-Wing screwdriver for that).
That beeing said, we didn't became fanatics of the series. Just the ordinary fans. ^^
Anyway, back to the GB games - back in the 90s, I played many of them on my Super Gameboy adapter on SNES.
The Space Invaders cartridge (or "cassette" as we used to call such a thing) had both a GB ROM and the SNES ROM inside of it.
And when played on the SNES, the GB ROM also took advantage of the SNES audio chip (SPC700) or second controller.
In a similar fashon, Kirby's Dreamland 2 also took advantage of the SNES audio (to play sound effects like wind and thunder).
You're welcome. While I had a C64 in my later childhood, I didn't exactly grew up with it.
Among my frist computers was a Sharp MZ-700, an 8-Bit machine with Z80 CPU and text mode/glyph based graphics.
What I like about the C64 is less the graphics, but the SID sound and the many interactive fiction games.
By the way, using that ancient C64 emulator is less difficult than it seems (many failed on it):
* Copy your D64 image to VC1541.000
* Run C64 executable
* Display the directory (type LOAD"$",8 (enter) then LIST (enter))
* Run the first program LOAD "*",8 (enter) then RUN (enter)
* Or run the program you got displayed earlier (LOAD"PROGRAMNAME",8 (enter) then RUN (enter))
Edit: Some typos fixed.
Reply 37 of 39, by OldCat
Same here - it's just that I got this one as a bonus with one of old computers. So, zero cost wins!
I actually did have Covox as a kid, came in a box with Electro Body (aka Electro Man) game. But being as lazy as I am, I will stick with PC Speaker and if I have enough of these chirping sounds, I'll just put some Sound Blaster clone inside. The trick, however, is that I have only two ISA slots in there, as well as two openings - it really is a very compact construction. So adding sound card would also require moving CF adapter somewhere else (probably into the slot on the side, where FDD is).
Reply 38 of 39, by Jo22
OldCat wrote:
I actually did have Covox as a kid, came in a box with Electro Body (aka Electro Man) game. But being as lazy as I am, I will st […]
Thanks for mentioning that game. I played Electroman before, but had no idea it was a cut-down version.
The original, Electro Body (shareware version), works just fine on my old 286, even in the emulated Hercules of my VGA card.
I've also found some scanned box art of the Polish version on Mobygames, which lists a lot more devices than Electroman does.
Makes me wonder why they got removed afterwards. 😕
For the CF card, I've got an idea, but it requires some tinkering: In the 2000s, Floppy-/Card Reader combo drives were made.
They included a slim 1.44MB drive along with an USB flash card reader in a single case.
In theory, you could remove the card reader part and install the CF adapter in its place.
Or you could attach a Gotek drive to the USB card reader.
Anyway, these are just some ideas that came to my mind. 😀
Reply 39 of 39, by OldCat
Jo22 wrote:
I played Electroman before, but had no idea it was a cut-down version. The original, Electro Body (shareware version), works jus […]
Overall, same applies to all X-Land games of that era: Electro Body, Heartlight PC and Robbo. The original Polish versions all supported Hercules, CGA, EGA, VGA, but in later Epics versions for US marker the support for older graphic cards was dropped. Nothing was explicitly cut when it comes to content, however.
I talked about it with Maciej Miasik (one of the creators of Electro Body, who later on worked as a producer on the first Witcher game - met him on one of gaming fairs in Poland, possibly Digital Dragons) and I think his answer was that they recompiled the game for Epic and somewhere around that point the support for Hercules, CGA and EGA was dropped, as in US this was pretty much obsolete (equivalent of backward compatibility).
The trick is that when years later Mr Miasik released these games for free, the code base he used was the one from Epic games, not the original older one, simply because it was easier to get ahold of (the old one was already lost at that point, I believe). So my recommendation for people who would like to play them on the older systems is to find the original versions and manual scans (necessary due to copy protections systems). I can help with that, if needed.
