Can make together the Colonel's Bequest PC with AMIGA sounds?
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Postby slx » 2018-5-06 @ 19:36
Can make together the Colonel's Bequest PC version with AMIGA version sounds?
User avatar
slx
Re: Can make together the Colonel's Bequest PC with AMIGA sounds?
Postby robertmo » 2018-5-13 @ 05:15
I think it already exists:
Atari ST version has amiga sounds and roland mt-32 music ;)
User avatar
robertmo
Postby slx » 2018-5-13 @ 17:37
Thank you!
I get the .st files of this game and opened them and I use them on scummvm and it works great BUT it uses the MT32 for the sounds like the DOS version! There aren't the AMIGA sounds in this game if I set the MT32 on in the scummvm!
User avatar
slx
Postby slx » 2018-5-13 @ 18:49
So, the ATARI ST version is not good MT32+AMIGA combination!
User avatar
slx
Postby robertmo » 2018-5-13 @ 18:56
try some atari emulator
User avatar
robertmo
Postby slx » 2018-5-14 @ 09:48
I tried with hatari 1.9.0... but the game does not start!
User avatar
slx
Postby slx » 2018-5-26 @ 17:03
I was able to use the Atari sounds but these are not the same as the sounds of the AMIGA version!
User avatar
slx
Postby slx » 2018-6-19 @ 03:23
I thought someone can solve this thing because I saw what they were able to do with the King's Quest 4.
User avatar
slx
Postby F2bnp » 2018-6-19 @ 07:43
Perhaps ScummVM can do it?
User avatar
F2bnp
Postby slx » 2018-7-29 @ 16:17
I've tried with ScummVM, too... and I got the same result!
User avatar
slx
Return to DOS
Who is online
Users browsing this forum: knowledge [bot] and 1 guest
