First post, by konc
Hello,
Could someone kind enough measure such a shield and share x,y and hole diameter? Unless of course you know some link with this information that I wasn't able to discover.
I'm talking about the classic/generic shield as in the below photo which snaps in place from inside the case, not the kind that is case-dependent and you screw it on.
Thanks in advance
39.38 KiB
Reply 1 of 4, by gbeirn
Y appears 1 1/2” on center.
1.03 MiB
Reply 2 of 4, by gbeirn
X appears 1 1/8” on center
947.2 KiB
Reply 3 of 4, by gbeirn
Diameter appears 5/8”
511.29 KiB
That’s as accurate as i can measure right now.
