PC tower cases by year
First post, by arncht
Hi
I would like to create a topic about the old pc cases and we could use some "collective memory" to recognize the old pc cases.
I mean if you remember - "I saw somewhere same/similar case from this year, with this configuration" - you can share this information with us.
That helps to build more authentic retro computers.
If you looking for an old case, get a photo, and I will mark as "wanted".
Be honest, I am a big fan of the "authentic" configurations, so if I build something, I try to collect every part which was available at the specified age.
I created a big table for it: https://docs.google.com/spreadsheets/d/1Ra5Jv … dit?usp=sharing
1992
1993
1994
July 1994
January 1995
March 1996
dj5AiQq_d.webp?maxwidth=760&fidelity=grand
Second half of 1997
SnEHhgN_d.webp?maxwidth=1520&fidelity=grand
"Lanny" ca 1992-1993
  • This is the closest picture I could find that matches my first *real* PC back in 1998. It originally started it's life as a custom Point-Of-Sales computer in my dad's store, around 1992-93. I'll put this one around the early 90s.
"Palmer" ca 1993
wanted by: arncht
  • I had same case in May of 1993. That was my first pc, a 386DX-40.
"Norman" 1994-1996
  • That was originally a budget 486 configuration from 1996, but I friend of mine had a DX2-66 config with similar case from 1994. The difference, it had a black inside and the manufacturing quality looked less cheap. So the case is from ca 1994-1996.
  • I think those started appearing in 1996 or so, and were somewhat common in low-end builds until the end of the 90s.
  • July of 1996 - PC Mag 6x86 advertisement
  • Apr of 1994 - Hungarian Chip magazine
"Howard" ca 1996-1997
  • It as was the case for a very late 486 rig from end of 1996 or early 1997.
  • I have the mid-tower version of this case, but it does not have the MHz displayer or turbo switch. It's pretty sturdy, and plenty of room for cable management.
  • Although the plastic bezel has an attractive design, the chassis itself is pure garbage. I can confidently say it was the worst case I ever owned.
"Dominick" ca 1992-1999 (sleep button instead of turbo from 1995-1996)
  • It came with an MMX233 in it but it was likely upgraded, the turbo display is 2 digits. I used to see this very case from small computer businesses for years, but I really can't say much about it. I've been looking to find where these came from because I know for a fact they are extremely ubiquitous. Later versions of it came with 3 digit displays.
  • My father had a 386SX-25 in a case with this bezel, given to him new by his work, that was around mid-1992.
  • I have two cases with really similar look. One had a 486SX with VLB and the case has a turbo button, the other was a Pentium 133 and the cas has a sleep button. Looks like they got produced for quite some time. Also the 486 has a big plastic feet. The pentium has none, but it have been removed I think because the bare metal is toutching the ground instead ...
  • I would bet 386 machines circa 1992 would have been the earliest showing of it. I've never seen one with a sleep button, only the same case with turbo and a triple digit display instead of double. Though I'm not sure if the 3 digit ones were a later iteration or just 3rd party swaps of the display.
"Carson" ca 1997
  • The first small case (on the photo) was used in a 1997 build from Russian company Formoza: Lucky Star 5I-VX1F, ceramic Pentium MMX-200 @ 166 MHz (I don't know why the CPU was underclocked), 2x32 MB PC66 SDRAM, 3dfx Banshee 16MB, SB AWE64 Gold, other parts (HDD, CD-ROM and FDD) were already lost when the PC had been found by me. Now the VX-motherboard is replaced with a LS 5MVP3, as it is better than the 5I-VX1F.
In Win IW-A500 1996-2000
  • I found some web pages from September of 1998.
  • I just looked at the 440LX motherboard that came with my copy of this case. I found a few date codes, the latest was 9807 on the PCB itself. So at least my copy of the case was probably sold in 1998.
  • Not sure exactly when those first showed up, but my friend's father had one with an ATX P!66 classic inside. I am pretty certain it was assembled in 1996.
  • I had a P2 and later a P3 system in this case and want one in good condition badly.
  • December 1997 PC Mag (Nova PII-266XC)
  • September 1996 PC Mag (DirectWave)
"Silvester" ca 1999
  • very late AT case with low cost Celeron 366 config, looks very similar to "Dominick"
Overdoze of the demoscene
Reply 1 of 227, by arncht
113.81 KiB
There is another one:
For me it looks more "486" style than the previous case.
Reply 2 of 227, by arncht
58.71 KiB
If you have one, I would like to buy it 😁
Reply 3 of 227, by arncht
541.46 KiB
242.52 KiB
In Win IW-A500
Reply 4 of 227, by feipoa
arncht wrote:
There is another one: It as was the case for a very late 486 rig from end of 1996 or early 1997. For me it looks more "486" sty […]
I find this case the most attractive. Where did you get it? Are there more? Does the right-most button look strange in this image?
Reply 5 of 227, by shamino
arncht wrote:
In Win IW-A500 I found some web pages from September of 1998. […]
In Win IW-A500
A relative bought one of these a long time ago from a friend's family. It had a 440LX motherboard with a P2-233MHz in it. It was apparently built by a shop - it has a shop sticker on the front.
Nowadays I have it, so I checked and it looks like an exact match.
Reply 6 of 227, by arncht
No, i dont have more. I also like it, i want to renovate it later.
I think the right button is the reset button. It is harder to press it.
Reply 7 of 227, by arncht
shamino wrote:
In Win IW-A500
OK, thx. The 1998 looks correct (maybe late 97). the inside is the typical "BX age", with the rotated PSU.
Reply 8 of 227, by krcroft
dell-dimension-xps-p90-pentium-90mhz-1.3gb-hdd-32mb-ram-tower-pc-1.39__20968.1490152666.jpg
48.51 KiB
Dell Dimension XPS P90, circa June 1994
Parents gave me one as my HS graduation gift, which blew me away. More photos here:
https://www.recycledgoods.com/dell-dimension- … b-ram-tower-pc/
Reply 9 of 227, by BeginnerGuy
How about if I can't place the year>?
Can anybody place a year on this case I recently obtained? It came with an MMX233 in it but it was likely upgraded, the turbo display is 2 digits. I used to see this very case from small computer businesses for years, but I really can't say much about it. I've been looking to find where these came from because I know for a fact they are extremely ubiquitous. Later versions of it came with 3 digit displays.
1.38 MiB
Edit: Vogons users place this case around 1992 coming with 386 class machines on the low end, and later models sporting Pentiums without a turbo button probably circa 1995-1996.
Sup. I like computers. Are you a computer?
Reply 10 of 227, by Revolter
Hi,
I have a case of this model, and I don't intend to use it. The chassis itself has seen better days, but I can part with the face panel no problem (it's easier to ship it that way, too). PM me if you're interested.
Celeron 800, 512MB, GeForce2 MX, ES1938S/DB S2, Windows ME/DOS 6.22
Reply 11 of 227, by Anonymous Coward
I would avoid this one. Although the plastic bezel has an attractive design, the chassis itself is pure garbage. I can confidently say it was the worst case I ever owned.
The cases with the green power buttons were also pretty good ones to avoid. I think those started appearing in 1996 or so, and were somewhat common in low-end builds until the end of the 90s. Sometimes in the late 80s and early 90s you could luck out with a generic case with decent build quality, but the generic cases of the mid-late 90s were overwhelmingly poor.
The Inwin A500 on the other hand was a real winner. Not sure exactly when those first showed up, but my friend's father had one with an ATX P!66 classic inside. I am pretty certain it was assembled in 1996.
Reply 12 of 227, by Brickpad
arncht wrote:
The attachment IMG_20160822_221652.jpg is no longer available
    95.46 KiB
Reply 13 of 227, by appiah4
In Win IW-A500
True. I had a P2 and later a P3 system in this case and want one in good condition badly.
Reply 14 of 227, by arncht
Anonymous Coward wrote:
I would avoid this one. Although the plastic bezel has an attractive design, the chassis itself is pure garbage. I can confident […]
i am from hungary. in the east european countries you could buy just this "garbage", but it was the same for most of the computer parts. an average (i mean in those countries) computer cost more 3-6 months of salary at those time.
so simply no market for "branded" computers and computer parts, they started to be popular just from very end of the 90s. if i want to build an "authentic generic" computer, i have to put to these cases.
the inwin quality is amazing, but the construct itself is horrible.
i have bought two years ago, as a NOS case. since then i realized, the biggest treasure is a good condition case. 😀 they are much rarer than any another computer parts.
Reply 15 of 227, by arncht
i upload the images to the imgur, and link to the first message with the information.
i also give a random name for the cases to recognize them.
done 😀
Reply 16 of 227, by JidaiGeki
Reply 17 of 227, by Deksor
Reply 18 of 227, by BeginnerGuy
Thanks for the input guys. So 1992 seems logical, at least for the original. I've seen this case in a lot of business class PCs, so I would bet 386 machines circa 1992 would have been the earliest showing of it. I've never seen one with a sleep button, only the same case with turbo and a triple digit display instead of double. Though I'm not sure if the 3 digit ones were a later iteration or just 3rd party swaps of the display.
It's not my favorite case in the world, primarily because of the ugly round power switch, but it gets the job done 😎
Reply 19 of 227, by techweenie
I have the In Win IW-A500. My high school used it extensively, and as such I'm not willing to part with it. Very nostalgic for me. I have it setup with a PII 450 running Windows NT 4.0. The school had them fitted with PII 266 and upgraded from NT 4 to Windows 2000 the year I left. They weren't very fast even for the time.
