First post, by Pabloz
I had the front plastic of a retro PC Case (one of those with turbo buttons, cheap one that yellowed like cheddar cheese)
I was planning on doing a retrobright, but to be honest i did retrobright a lot of other things in the past using liquid hydrogen peroxide and even used some with salon cream 40% , for example:
A ps2 mose
A creative audio drive bay
A keyboard.
And they all yellowed again after 1 year, or year and a half, even if the plastic was kept with zero light with no direct contact with the sun. So retrobright might look good at first, the thing blows after some months. So i wanted to try something else because i was tired of retrobright, its too much work for something that will not last long.
So i bought spray paint. white spraypaint and proceeded to paint the retro PC front plastic.
The result was really bad because the color was so white, white as a t-shirt, or even more white than milk.
I wonder if someone here did a white paint job on plastic for a retro pc , and what color was used that works, because i think the true color is different, more like a mix of white and very light grey color, but you can´t find spraypaint of that particular color.
Reply 1 of 16, by tannerstevo
I don't know where you live, but here in the U.S. you can take a side panel or some part that is the right color to an auto parts store that sells paints, and they can scan it with a laser and mix a custom color. It may not be cheap, but it is an option.
If you do this, make sure you tell them it is for painting on plastic.
Reply 2 of 16, by MCGA
I've used Rust-Oleum Satin Fossil and another lighter color -- sorry, I can't recall which one -- and I'm still really happy with the results. When next to my beige speakers, monitors, keyboards, and so on from the eighties and nineties, it's right at home.
I like the Satin Fossil the best, since it's a darker gray-ish/beige, so more inline with the eighties multi-beige PCs. I'm going to paint the front bezel of my 14" CRT with it once I get some free time( I'm not a fan of bland all gray cases ). And as far as a paint, it goes on nicely(evenly with 3 coats), drys really fast, and has held up repeatedly to the weight and movement of my 17" CRT sitting on it.
Reply 3 of 16, by .legaCy
I had the opposite experience,first i attempted painting plastic, it turned out not so good because of my skill, but after 6 months that thing became disgusting, idk what happened but it became a nasty brownish color.
With everything that i retrobrighted it worked pretty well, i have a microsoft keyboard that is holding on pretty well.
Useful links
[ How to Multiboot any OS | Rebuilding GOG Installer for Win9x | 486DX-4 Build | S7 Time machine Build |
twitch stream (in portuguese)
Reply 4 of 16, by wiretap
As said by tannerstevo, the best option is getting a color matched to something you want. Take in a component to an automotive paint store.. they'll scan the color. My local automotive paint store (in the US) will do spray cans of the color you choose for less than $10 per can. From there, you'll want to lay down a light coat of plastic safe primer so the paint adheres good.. then do a few light coats of the paint, then use something like a satin clear coat. Always test the paint job out first on something you can throw away to see if you like the outcome.
Example of a build I sprayed with Honda Civic Si blue.. yes, I made a Hooli Box from the show Silicon Valley. 😜
Circuit Board Repair Manuals
My Project List
Reply 5 of 16, by Shagittarius
It's no signature edition.
51.37 KiB
Reply 7 of 16, by gdjacobs
I haven't watched the latest season, but I'm assuming the signature was the butt of some joking.
Reply 9 of 16, by Almoststew1990
I tried painting my case. I sandpapered it all off, applied undercoat and then did several coats of paint and still managed to balls it up.
Just bought
Cleaned
Stripped
Undercoat
(pro tip, don't use red automotive undercoat before white paint!)
After
The inside looks good, the front panel is vert uneven. The paint is wearing down after about a year with noticable scratches and this was with decent paint. It doesn't quite fit together as well as it did before as it is all a couple of mm larger due to the multiple layers of paint! I kept applying more layers to try to get a better finish but it was just the very vibrant undercoat showing through.
Next time I'll use a white undercoat an only do two coats.
Reply 10 of 16, by feipoa
Are there beige primers you can use? Or what about paint+primer all-in-one?
Reply 14 of 16, by retardware
I once had a very nice 1970 color TV (even with ultrasonic remote control, which was rare luxury in 1970) that was in perfect technical shape. But its case was scratched and discolored, apparently because of an overly zealous housewife which cleaned it way too often.
I ended up removing the insides (aww... more than 30kgs), painting the whole case in red, reassembling and...
...it was BEAUTIFUL!
Considering to do similar with my 486 case...
Reply 15 of 16, by wiretap
denforth wrote:
wiretap wrote:
http://i.imgur.com/ouG2Pggl.jpg […]
This reminds me so much of the Cobalt RAQs the boss decided to buy almost 20 years ago.
This particular net appliance I used the case from was a Bluecat Adonis 500 I picked up from ebay for like $25. I put my own components in it though -- I think I made it during the first or second season of Silicon Valley.
My Project List
Reply 16 of 16, by hwh
I've never tried to paint a case, though surely the day cometh. One issue I noted is that of textured paint (for instance, a 5150, but cases frequently have some kind of textured finish on them). For this reason, I suspect touching up is less invasive than repainting, but I don't know much about quality painting work.
I never noticed issues with hydrogen peroxide treatment. If anything if you overdo it I would be glad to see a part return its original finish and aged color, but I am sure it all depends on what exactly you treated and how you did it.
