DOS pgm can write but not read
General information and assistance with DOSBox.
Postby smichelsen » 2018-6-06 @ 19:41
I have an '80s DOS program that can create and save small files, and also load them for use later.
Within DOSBOX I am able to save a file to the mounted "A" drive (a folder on my c: drive).
However, when I attempt use the pgm to load the file back in, I get a disk error.
What could be the cause here?
I have read that doxbox is not for games, but so far this emulator has worked better than the others I have tried (vdos, vdosplus).
Anyone care to suggest an emulator? I would like to avoid using a full dos app inside an emulator!
Thanks,
Steve
smichelsen
Re: DOS pgm can write but not read
Postby Gene Wirchenko » 2018-6-07 @ 01:31
smichelsen wrote:I have an '80s DOS program that can create and save small files, and also load them for use later.
DOSBox is intended only *for* games. However, some of us apostates refuse to repent. <BEG>
I use it for running a text editor and some utilities that I have written in QBASIC. It works fine for me.
Take care though.
Sincerely,
Gene Wirchenko
Gene Wirchenko
Postby Qbix » 2018-6-07 @ 13:21
Thanks,
Steve
I would suggest that you try a SVN build of dosbox like https://blog.yesterplay80.net/dosbox-ece-en/ and the DOSBox r4112.7z (need to unzip it with 7zip or winrar)
We have made quite a number of fixes.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby root42 » 2018-6-07 @ 13:59
While many people here are using DOSBox, because it is well suited to games, and emulates a variety of sound cards, if you only want to run some "serious" applications, you might want to use VirtualBox and simply install either FreeDOS or a copy of your favourite DOS in it. The media handling (disk images) is usually much less hassle than with DOSBox.
Soldering, retro game reviews and more on YouTube and Bonus videos
Me playing games on my 286 and on my Sega MD2 on Twitch
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, schlae AdLib, PC MIDI Card + SC55MkII, XT CF Lite, OSSC 1.6
User avatar
root42
Postby smichelsen » 2018-6-07 @ 18:07
Gene - yes I did mean to say that DosBox is ONLY for games. Oops.
Qbix - I have "DOSBox0.74-win32-installer". Is there a better/faster/stronger version, that could possibly allow my pgm to read as well as write? I could not find anything different for windows on the yesteryear page.
root42 - I'm a newbie at DOS emulation on my 64bit PC - I read that one must be careful about installing a copy of DOS as one can risk the copy of windows that runs the PC. I get that DOS needs to be installed "into" the emulator. Is there a step-by-step install guide somewhere - I don't want to botch that up!
smichelsen
Postby DosFreak » 2018-6-07 @ 18:09
"DOS pgm" is pretty vague. How about you tell us what program you are using?
Also post the commands you are using to mount your drives and launch the program.
User avatar
DosFreak
Postby smichelsen » 2018-6-07 @ 18:28
Dosfreak:
I used
mount a c:/dosprogs/
to mount a folder and have it seen as the A drive in my DOS pgm, which I ran from that folder.
My program is a multi-image slideshow editor created by "Audio Visual Laboratories" called "AVL ProCall", which ran on an 8088 PC with a "Genesis boardset" installed. The boardset controlled (via RCA cables) up to ten "AVL Dove" dissolve units, which in turn each drove 3 slide projectors. See my page www.stevenmichelsen.com/AVL and scroll down a bit to see a video of ProCall being used.
I won't actually be able to drive a slideshow using ProCall in my 21st century PC, (gotta have that 8-bit board installed!) but at least I can reacquaint myself with how it works.
smichelsen
Success!
Postby smichelsen » 2018-6-07 @ 18:46
QBIX - Holy Crap! I take it all back! I just ran the version of Dosbox that I got from the yesteryear page (DOSBox ECE r4112), and it ALLOWED ME TO WRITE AND READ FILES! I see that it is identified as the same version as the "other" dosbox, v 0.74, but this is the "community version" and does indeed allow me to do what I want to do. THANK YOU VERY MUCH.
Steve
smichelsen
Postby Qbix » 2018-6-07 @ 20:01
ECE isn't the needed part. the 4112 is :)
Have fun
User avatar
Qbix
DOSBox Author
Return to DOSBox General
Who is online
Users browsing this forum: DosFreak and 2 guests
