Dynrec - ARM 64-bit backend
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby M-HT » 2018-6-09 @ 12:33
I created a backed in the dynrec for 64-bit ARM (ARMv8, little endian).
Detection in configure is included, but in case it doesn't work, following definitions should be set in config.h
Code: Select all
#define C_DYNREC 1
#define C_TARGETCPU ARMV8LE
#define C_UNALIGNED_MEMORY 1
Patch for revision 4112 is in the attachment.
Changed files:
src/cpu/core_dynrec.cpp
src/cpu/core_dynrec/Makefile.am
configure.ac
New file:
src/cpu/core_dynrec/risc_armv8le.h
armv8-r4112.diff
(53.01 KiB) Downloaded 73 times
M-HT
Re: Dynrec - ARM 64-bit backend
Postby bruenor41 » 2018-6-09 @ 12:51
Tested last day on 6 different devices and 20+ games. No crashes or unusual behaviors. Most important : No performance regression against 32 bit backend! Good work! :)
bruenor41
Postby krcroft » 2018-6-09 @ 14:19
This excellent work just future-proofed dosbox on aarch64 when it will eventually displace the 32bit arm archs.
Excellent addition!
User avatar
krcroft
Postby Qbix » 2018-6-11 @ 15:39
Thanks a lot!
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Qbix » 2018-6-13 @ 09:24
Added it.
User avatar
Qbix
DOSBox Author
Postby M-HT » 2018-6-14 @ 19:59
Thanks to more testing by bruenor41 a bug was found. The fix is in the attachment.
armv8-r4118.diff
Patch for revision 4118
(663 Bytes) Downloaded 66 times
M-HT
Postby Qbix » 2018-6-14 @ 21:07
commited in 4119. Thanks!
User avatar
Qbix
DOSBox Author
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 2 guests
