Turok Dinosaur Hunter Help
Getting old Windows games working.
Postby yuljk » 2018-6-09 @ 17:23
Hi guys - I'm attempting to get the original Turok working on Windows 10.
I have the original CD's - the game installs fine, however when attempting to launch with 3dfx glide using the latest dgvoodoo I get 'This game only supports Voodoo Rush'. I have already selected Voodoo Rush as the card in dgvoodoo.
Has anyone had any success getting this game to work with either D3D or Glide with dgvoodoo?
Many thanks!
yuljk
Re: Turok Dinosaur Hunter Help
Postby stranno » 2018-6-09 @ 19:56
Not sure if you want the original thing for a reason but there's a modern port by SV Kaiser. With improved gameplay, level design, graphics, controls, widescreen, etc.
User avatar
stranno
Postby yuljk » 2018-6-09 @ 22:13
Yeah - I was thinking of running this on an old Thinkpad, which isn't up to the task of running the HD version.
yuljk
Postby leileilol » 2018-6-10 @ 01:03
The Voodoo Rush version is an exclusive OEM version for certain Voodoo Rush boards (IIRC the Intergraph Intense 3D Voodoo). You'll need the proper retail version instead if you expect that to work with any Voodoo card (and wrapper), or just any other 3d vidoe card since Direct3D is also supported in retail.
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
DOSBox is not for running Windows 9x
SGL != Glide
User avatar
leileilol
Postby yuljk » 2018-6-10 @ 13:34
Thanks teleguy - I'm using the patched .dll from that post - That's cleared up the error, however I'm now seeing 'Driver failed, application terminating'.
There was a reference on zeus's forum to changing hex values, as the game thinks any dll's in the game directory are drivers. However the hex entry doesn't exist that he's referring to.
yuljk
Postby teleguy » 2018-6-10 @ 14:00
Can you upload your exe?
teleguy
Postby yuljk » 2018-6-10 @ 14:56
Managed to get this working now - Switched across to the D3D release instead.
Firstly I replaced 2a 2e 64 6c 6c 2a with 76 2a 2e 64 6c 6c in Turok.exe to get around the driver initialisation error.
I used ddrawcompat instead of DGVoodoo (Couldn't get the game working with this) and then applied the widescreen fix from https://pcgamingwiki.com/wiki/Turok:_Dinosaur_Hunter#Widescreen_resolution
The game runs well so far on Windows 10.
Now to convert the CD game music to .ogg in order to ensure it loops correctly!
yuljk
Postby yuljk » 2018-6-10 @ 15:41
I tried using a the fixed winmm.dll for Windows 10 along with the three libvorbis dll's and ripping the music to .ogg format, however I get no music in game.
Has anyone figured out how to use winmm.dll with Turok 1?
Getting there!
yuljk
Postby yuljk » 2018-6-15 @ 16:29
Didn't have any luck using various winmm.dll options to get Turok music working, and _inmm.dll didn't work either.
In the end I created a .bat to mount the .iso and unmount automatically after closing the game.
yuljk
Return to Windows
Who is online
Users browsing this forum: Tomas. and 0 guests
