Windows 95 won't load and just crashes :(
Getting old software/games running on older hardware.
Re: Windows 95 won't load and just crashes :(
Postby BeginnerGuy » 2018-6-14 @ 02:27
tpowell.ca wrote:
candle_86 wrote:No where not, i tried to remove hardware and turn it on, then the motherboard started to smell like burning silicone :(
Shes dead Jim.
Sorry, I couldn't resist.
Sounds like something is shorting or a bad power supply.
Most likely unrelated to the Windows 95 issue though.
Maybe you'll be lucky and it may not be fatal.
I'd suggest removing EVERYTHING, and triple checking for anything loose inside your case. Screws, slot adapters, badly inserted RAM...
Then start small.
CPU, RAM and Videocard.
Then Disk, CD-ROM
After pulling cards I'm thinking maybe his motherboard is touching bare metal in the case too. Unless there was a cloud of smoke and visibly roasted traces on the board, it could be alright.
Sup. I like computers. Are you a computer?
User avatar
BeginnerGuy
Postby candle_86 » 2018-6-14 @ 05:27
no smoke, just the smell of very hot silicone lol, ill take it apart later
Ryzen 5 1600 - Gigabyte B350 Gaming - 16gb DDR4 3200 - 240GB M.2 - Windows 10 Pro
Core i3 3470 - Dell B75 Mobo - 4gb DDR3 1333 - 500gb HDD - Windows XP
Opteron 180 - Epox EP-9NPA+SL - 2gb DDR500 - 320GB HDD - Windows XP
User avatar
candle_86
Postby yawetaG » 2018-6-14 @ 19:12
BeginnerGuy wrote:
Shes dead Jim.
Then start small.
Then Disk, CD-ROM
A short due to a screw in the wrong place could very well be a decent explanation.
yawetaG
Previous
Return to Software
Who is online
