Retro OSes for retro computers
Reply 20 of 263, by root42
gdjacobs wrote:
I can't find any of the old versions of Peanut Linux. I remember running it via loopback off a FAT filesystem.
You can try zipslack:
https://mirrors.dotsrc.org/slackware/slackwar … -11.0/zipslack/
This is Slackware 11.0 running on a FAT partition via UMSDOS.
YouTube and Bonus
Reply 21 of 263, by matze79
This is small linux, 2 floppys, can run inside 1Mb RAM when root is mounted from floppy.
you can install its kernel to harddisk and use it together with some older slackware distribution (3.3).
    small.7z
    1.42 MiB
    140 downloads
Reply 22 of 263, by lolo799
debs3759 wrote:
Have you tried Plan 9 from Bell Labs?
I have known about it for years but never tried it, there is even an old port of it to the BeBox, thanks for the link!
All the download links from the archived official website are dead https://web.archive.org/web/20010224073654/ht … eanutlinux.org/
Found this on a random magazine coverdisc:
6.13 KiB
7.11 KiB
Get it: https://mega.nz/#!epxD2DbJ!93CVV7UCNORqt6nfF2 … y8qL8KGprdm91mQ
Stiletto wrote:
debs3759 wrote:
This thread should be pinned.
It has now been pinned. 😀
Thanks!
root42 wrote:
Back in the mid 90s when I got my first CD ROM drive, one of the cover CDs contained a shareware version of TSX-32. A multitasking, partially DOS compatible operating system for 386 and better:
https://en.wikipedia.org/wiki/TSX-32
I would have to try it out again to be able to say anything meaningful about it though.
That sounds interesting, thanks.
ZipSlack is certainly a worthy mention in the thread.
I put Small Linux on the previous page, you may have glanced over it due to all the Linuxes in one post!
I have older versions of it if you're interested.
Reply 23 of 263, by gdjacobs
root42 wrote:
You can try zipslack: […]
UMSDOS isn't very desirable due to the inherent restrictions involved. IIRC, Peanut used an image file.
Edit: No it did not. So, the mystery question is, what was the distro I'm thinking of. Low resource consumption, X based GUI, ran off a loopback mounted file image.
Reply 24 of 263, by lolo799
There's Basic Linux on the last page and a distro based on Slackware called LoopLinux https://web.archive.org/web/20000903132357/ht … otti/looplinux/
Reply 29 of 263, by lolo799
Found a working mirror for LoopLinux at ftp://bbc.nvg.org/pub/linux/sunsite/distribut … inux/index.html
SliTaz needs quite a lot of ram, even for the mini and loram versions, but it looks cool for Pentium machines.
How usable is DSL with the minimum required specs?
Time for an update, today will be about BeOS.
It started its life on a machine powered by AT&T processors, then moved on to the PowerPC 603/604 and to the Intel Pentium patform.
Be distributed almost all of the versions of BeOS either as free to install or as LiveCD to test, and not just the BeOS 5 Personal Edition usable installable as a loopback filesystem on DOS/Win9x or Linux.
Some were packages directly downloadable from its website, unfortunately impossible to find, and some were distributed on magazines cover discs.
After the demise of Be, Inc. two german companies continued the development of the OS under the name Zeta, the first one, yellowtab produced a LiveCD of its version 1.1.
Here you have the Preview Release 1.2 for PowerMac
74.91 KiB
https://mega.nz/#!j5AwnQBB!S0deZZbysXYreYtYwl … iIrGF6W5OHmbNBo
Be sure to check the compatibility list at https://web.archive.org/web/19980124033142/ht … sreadylist.html
The R3.2 Demo CD
33.68 KiB
https://mega.nz/#!mwI2SYRQ!dfgXeqb7F7SNqUZXYX … YZ0FEyHBVfDjvRY
Compatibility list: https://web.archive.org/web/19980520211743/ht … sreadylist.html
The R4 Demo CD, I extracted the BeOS track and bootfloppy image from a french magazine coverdisc:
62.01 KiB
https://mega.nz/#!6oIWmCSR!won4b_F45P-YBKnQNX … N8GTFeZ2abdCby4
Compatbility list: https://web.archive.org/web/19990421064114/ht … list_intel.html
The R4.5 Demo CD, distributed with a japanese magazine:
33.39 KiB
https://mega.nz/#!GkQ0XKjZ!1HeD-QqtD0kazXjTj5 … s3tDcpFInTWOC-o
Compatibility list: https://web.archive.org/web/19990429193804/ht … list_intel.html
The BeOS 5.0 Personal Edition and its updates can be downloaded from ftp://ftp.ntua.gr/mirror/BeOS/
And Zeta Live 1.1, which was available as a download on yellowtab website long ago:
29.79 KiB
https://mega.nz/#!2hBilaLJ!jKNK573S85iqCV0ZPf … FvN5oyEaj_lUcFE
Reply 30 of 263, by leileilol
I found it unusable with my am5x86160 10 years ago. The VESA driver didn't work very good on the ye old Trio64 either.
long live PCem
Reply 31 of 263, by xjas
^^ I've used it on a P233MMX with 64MB, but that's already a couple generations newer. Took a few minutes to boot off the CD but after it finished loading it wasn't too bad. Didn't try the browser. I'd think it'd be pretty painful on any less memory than that though.
Reply 33 of 263, by lolo799
Right, it really needs a Pentium and more RAM than what a 486 usually had back in the days.
Davros wrote:
I wonder if anyone has tried BeOS 5.0 Personal Edition under win 10 ?
I'm sure installing it is not the problem, but running it on recent thus unsupported hardware on the other hand, I expect it to crash long before you see your mouse cursor...
Reply 34 of 263, by lolo799
Time for a small 360K size update, so far the lowest specs machines supported in the thread were 386 with 2MB of RAM, but if you got an older machine, such as an original PC, a XT or a 286, this post is for you.
If you want use a flavour of Unix on your oldest PC and compatible system, you're in luck, there are a few options:
-Minix in its verson 1 and 2, an open source clone of Unix, available on those websites:
https://wiki.minix3.org/doku.php?id=www:downl … reviousversions
https://www.minix-vmd.org/cgi-bin/raw/pub/minix/
Check the hints page for low end machines: https://minix1.woodhull.com/hints.html#small
-ELKS, previously known as Linux-8086, is, quoting its FAQ, "the Embeddable Linux Kernel Subset, a project to build a small kernel subset of Linux (which will provide more or less UNIX V7 functionality within the kernel) that can run on machines with limited processor and memory resources."
Check its website and FAQ: http://elks.sourceforge.net/
Get old 0.1.0 and 0.1.4 disk images at https://sourceforge.net/projects/elks/files/E … 0Disk%20Images/
and the newer 0.2.0 at https://github.com/jbruchon/elks/releases
11.02 KiB
Lastly, if you want to see the commercial OS QNX 2 running on your retro computer, you can try the QNX 1989 Demo Disk, you can't do much with it though, but it's still worth a try:
44.76 KiB
3.15 KiB
7.9 KiB
qnx1989.zip
218.73 KiB
135 downloads
Reply 35 of 263, by gdjacobs
Coherent is available.
https://en.wikipedia.org/wiki/Coherent_ ... ng_system)
V2 can run on 8086 and up (no luck yet finding disk images). V3 can run on 80286 and up.
https://www.autometer.de/unix4fun/coherent/
Reply 36 of 263, by Merovign
Someone mentioned NextStep, but OpenStep officially runs on x86 hardware (though only retro hardware, not modern hardware): http://toastytech.com/guis/openstep.html
It's picky about hardware in the 486/early pentium range, particularly with IDE drives, and takes research.
I have a plan to load BeOS on a P4 laptop I have, then run Basilisk under it to emulate an early Mac, Because I Can. I already ran Haiku (in-progress BeOS update) on the laptop for a while.
*Too* *many* *things*!
Reply 37 of 263, by ArtiomWin
lolo799 wrote:
Lastly, if you want to see the commercial OS QNX 2 running on your retro computer, you can try the QNX 1989 Demo Disk, you can't […]
qnx1989.zip
I've some news on QNX: you can not just boot Demo disk, but install system to disk as QNX 2.x is now on Archive.org
Reply 38 of 263, by lolo799
Coherent looks interesting, I'll give it a try soon.
NextStep also officially ran on x86 in one of its later 3.x versions, and you're right, it was picky about the hardware.
If anyone wants a taste of what NextStep was, I suggest you try GNUstep:
http://www.aiei.ch/gnustep/
http://wiki.gnustep.org/index.php/GNUstep_Live_CD
http://mirror.noone.org/gnustep/
Reply 39 of 263, by Merovign
lolo799 wrote:
Coherent looks interesting, I'll give it a try soon. NextStep also officially ran on x86 in one of its later 3.x versions, and y […]
Also NextStep had other versions, like one for Sun machines (certain machines, of course, but interesting for those who might have them).
I keep meaning to get a copy of Coherent, I remember the old ads for it. I admit I'll probably run WSL first...
