play starcraft on my android?
Emulation of old PCs, PC hardware, or PC peripherals.
Postby Gaia » 2018-7-08 @ 20:41
Can I use dosbox to emulate starcraft? I don't have a pc, just my chromebook. The chromebook can use apps from google play.
I extracted the starcraft broodwar. Is there a way I can make c:/ activate setup.exe? What do I type in?
I may need a number of tries. Please help! Thanks.
Gaia
Re: play starcraft on my android?
Postby gca » 2018-7-08 @ 21:14
I would say no. Starcraft needs Win95 minimum (recent remaster probably something way more recent) and won't run on DOS emulated or otherwise as it was never intended to. Win95 or better running under emulation, maybe, but I doubt the performance would be worth the hassle.
User avatar
gca
Postby DosFreak » 2018-7-09 @ 02:19
DOSBox doesn't support Windows 95 as a guest.
I heard that Chromebooks may support Linux programs if they don't already if so then pcem,virtualbox,vmware,wine etc would be your best bet.
Closed
User avatar
DosFreak
Return to PC Emulation
Who is online
Users browsing this forum: DosFreak and 1 guest
