Reply 460 of 555, by hard1k
I can lend (for free, of course) a nice looking not so large PS/2 MCA machine with some 486 CPU if that helps you to take on such a project.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 461 of 555, by appiah4
I wish I could afford both this and Orpheus 😒 but for now I will be saving up for Orpheus, hopefully I can sign up for a later batch.
Reply 462 of 555, by ajacocks
LABS,
I built my Blasterboard, but I’m having issues with it not being detected, at boot. I’d like to send you a PM, but apparently I’m not yet allowed.
I did a check of the assembly, and did find one mistake, which I corrected. I’m not seeing the LED light up, and using the SB2.0 install.exe, the board isn’t detected. I have taken high res photos of both sides of the completed board. I have compared my board to the rev.B layout, from your GitHub repo, and didn’t see anything else obvious.
Can you send me a PM with an alternate way to contact you? Or, should I just post the photos publicly, and link to them?
Thanks!
- Alex
Reply 463 of 555, by Cyrix200+
If you post the high-resolution pictures somewhere, many people can take a look. 😀
What mistake did you make? There might be residual damage.
1982 to 2001
Reply 464 of 555, by ajacocks
Thanks, Cyrix. I initially mounted IC14 backwards. Unfortunately, I don’t have a functional 74LS tester, so I can’t be sure that the IC wasn’t damaged, but it seems unlikely.
The photos are here:
https://www.icloud.com/sharedalbum/#B0i5qXGF1O4ZUq
Many thanks to anyone who wants to take a look.
- Alex
Reply 465 of 555, by LABS
What do you mean it is not detected on boot?
SB 2.0 utility may not detect it if it is run on 486 or faster machine.
Did you solder IC14 wrong at first and powered it up? It might be damaged then.
Is OPL2 working? If the led did not light up - you will not hear any sound (check T1 MOSFET if it is ok), but you can try to detect it by a game or a tracker like Edlib.
There are no obvious mistakes on your photos, so the problem should be localized step by step.
Blasterboard: DIY SB2-compatible sound card on ATmega MCU
Sonic Buster 8: New 8-bit ISA sound card
Reply 466 of 555, by ajacocks
Sorry, I should have been more clear.
The machine that I am testing in is a 286/20, so speed shouldn't be an issue. I did indeed power it up, with the IC backwards, so it is possibly damaged. I'll replace it, and see if that makes any difference. However, my history with 74LS logic makes suspect that it is fine. Do you have any particular points that I should check, when diagnosing the board?
I'll try a tracker, and see if I can see it that way.
Thanks!
- Alex
Reply 468 of 555, by appiah4
James-F wrote on 2020-07-24, 05:17:
A SBPro2.0 version of this will be selling like hot cakes.
Just saying...
Well.. There is Orpheus for that, so.. But if this was Pro 2.0 compatible I'd be torn between the two for sure.
Reply 469 of 555, by DNSDies
LABS wrote on 2020-07-23, 11:23:
Labs,
I have this card installed on my Alaris Cougar build (IBM 486BL CPU) which is basically just a fast 386, and it sometimes doesn't detect unless I disable cache or change the clock speed from 100mhz to 75mhz.
Is there anything I can do to fix this? Like wait states or something?
Reply 470 of 555, by LABS
DNSDies wrote on 2020-08-27, 14:12:
...it sometimes doesn't detect...
Is it some particular game or overall?
If it happens only time to time, please check your BlasterBoard firmware version using this utility:
https://github.com/labs-lv/blasterboard/blob/ … ties/BB-VER.EXE
If your version is 2.0 - try to downgrade to 1.0. Otherwise - upgrade to version 2.0. You need to reflash the MCU for that.
Firmware can be found here:
https://github.com/labs-lv/blasterboard/tree/master/Firmware
Reply 471 of 555, by LABS
Back in stock. Due to demands PCB is green.
Reply 475 of 555, by matze79
Nice neutral Color!!! will PM when i get some money 😀
Reply 477 of 555, by LABS
Did you know that BlasterBoard's CD input can also be used as a stereo Line input? You can for example plug in your internal/external MIDI module and control its volume manually.
Here is my current perfect combo:
755.04 KiB
Reply 478 of 555, by appiah4
I use this trick with multi sound card setups a lot when the receiving card does not have a Line-In or AUX-In header, usually routing PCI to ISA for a multi boot setup. Of course you don't have the volume control like the BLASTERBOARD does but you can use the software mixer. It also makes muting the second card very easy. 😀
Reply 479 of 555, by matze79
Whats pricing for assembled Card ? is it still same ?
