Reply 60 of 555, by root42
LABS wrote:
Just received some fresh OPL2s 😀
I still have a bunch + DACs. Would love to put them to use.
YouTube and Bonus
Reply 61 of 555, by keropi
who else love the smell of fresh OPL2s in the morning? 🤣
Reply 63 of 555, by LABS
Ok, a production variant of a 2-layer PCB is ready in copper.
Now I need to drill a lot of <1mm holes to finish it.
As I don't have a drill press in my workshop - all holes for previous prototypes were 1mm and were drilled by hand. But now I need to replicate the production PCB and there are a lot of 0.5mm and 0.8mm holes, which need a drill press.
So during this week I made one using some plywood leftovers, but as you see it does not have a motor yet. I hope it will arrive very soon 😀
[attachment=-1]P1010622.jpg[/attachment]
    108.3 KiB
Blasterboard: DIY SB2-compatible sound card on ATmega MCU
Sonic Buster 8: New 8-bit ISA sound card
Reply 64 of 555, by bytestorm
WOW 😁. You´re workin fast! How great wouldnt a bugfree sound card be!! I have just been digging in the Sound Blaster jungle and I almost lost myselt in all the variations and buglists etc.. this couldnt come soon enough 😁
Please keep up the great work!
Reply 65 of 555, by matze79
wow amazing work 😀
Congratulations, this looks really professional.
Reply 66 of 555, by root42
Looking forward to a kit or schematics! Whatever you are going to release.
YouTube and Bonus
Reply 70 of 555, by Fagear
Vaudane wrote:
Loving the progress on this! I have also bookmarked this thread 😁
Bookmarked and subscribed indeed!
LABS, very nice project!
Really looking forward for it.
New 8-bit ISA Sound Blaster replacement, presumably without glitches and bad sound quality of variety of original boards will be great.
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 73 of 555, by LABS
Hello, there!
Finally had time to finish the prototype:
364.45 KiB
The digital part is on the left and analog part - a 4-channel mixer and amplifier - on the right. As seen it has 4 dedicated volume knobs for every sound source and one stereo output jack. The output has a delayed unmute circuit, so it doesn't pop on power up. As I already said in previous posts - the card has around -92dB noise level and does not catch internal computer noises as original 8-bit Sound Blaster cards did. After assembling everything on a single board the digital part runs super stable and smooth, BlasterBoard 2.0 is recognized as SoundBlaster 2.0 in all DOS games and demos I tried it on, autodetected as "Sound Blaster or compatible" by Windows versions prior to XP and runs nicely with Windows games - already tried Diablo, Hexen II, StarCraft and Half-Life.
After some minor layout fixes I will order first PCBs from manufacturer and make the firmware open for everyone.
Reply 74 of 555, by Fagear
Wow, that's great progress, really like the board! Fantastic work, LABS. 😳
I'd prefer it in SMD though. 😉
Reply 75 of 555, by Jo22
Looks good! Well done!
Reply 76 of 555, by canthearu
If I'm making it, through hole is easiest to assemble (with sockets and discrete components.
If it is being made in a factory, SMD is probably cheapest where possible.
But looks awesome either way. Need some artwork for the solder mask in the empty corner 😀
Reply 77 of 555, by LABS
Thanks, Max. Not as fast as I actually wanted it to happen, but anyway. I wish to go full-time...
Thank you!
That is the exact reason for using THT.
Yes, going to put tables with jumper settings there and project's name)
Reply 78 of 555, by dreamblaster
Looks superb !
Thanks for your support !
Reply 79 of 555, by LABS
Ok, just measured the output noise
Used RME Multiface for input @ 44100hz/32-bit float & WaveSpectra for Win
67.79 KiB
-94db RMS - not bad, right? With DSP, OPL2 and PC-speaker knobs set to max
But after connecting CD-audio and set its knob to max - I get this
74.08 KiB
Can hear silent, but audible constant high-pitched noise and variable noises from cd-rom motors 😠
Looks like a gnd loop.
Already tried messing around with gnd and R/L signals, connecting/disconnecting/buffering of cd-out on dedicated cd-gnd plane/checked solder quality/lp filtering - nothing works, the noise is in audible spectrum with peak @~8khz. If I connect cd-out via buffer to the power amp directly with a 3m cable - no noise at all, very clean signal, so there is a hope.
Unfortunately I do not have any hi-q cards with cd-in to check them out for possible solutions. Tried to trace hi-res photos of Aztec and Gravis cards and as I could see - nothing fancy here, just some filtering of inaudible freqs and gnds are connected, but maybe I just didn't notice something. How do their cd-ins behave by the way? Are they noiseless?
Anyone dealing with the same problem? Any suggestion will help. Thank you.
