How to find where data is stored?
Announcements, advice, random banter, unrelated discussion, et cetera.
Postby Zup » 2018-7-12 @ 18:18
I've got a disk that holds some data used by a program. It has a partition table and a FAT16 partition that seems empty (no files, even hidden).
I've made a disk image (using dd) before and after using that program, so I know what bytes were altered between runs. How can I know where are those bytes stored (i.e.: MBR, boot sector, between MBR and the first partition, at unused data blocks)? Is there a program that can help me find it out?
Thanks.
I'm selling some stuff!
User avatar
Zup
Re: How to find where data is stored?
Postby tegrady » 2018-7-13 @ 20:38
Possibly ISO Buster.
User avatar
tegrady
Postby vladstamate » 2018-7-13 @ 23:42
If you are on Linux you can hexdump the files you obtained with dd and then use any diff tool you want. If the diff is in the first 512 bytes then it updated the MBR for example.
In Windows a good free visual diff tool is WinMerge.
User avatar
vladstamate
Postby oeuvre » 2018-7-17 @ 03:41
data is stored in the balls
NetVista Sleeper i7 3770, 16GB, GTX750, 2xSSD + HD, XP/7/MacOS 10.13.6
ThinkCentre Sleeper Ryzen 7 2700, 32GB, RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Return to Milliways
Who is online
Users browsing this forum: Exabot [Bot] and 3 guests
