Reply 20 of 45, by RichB93
Hmmm... so, the RAM has been soldered and the cards work! But, it’s show 6MB of TMU RAM, not 8MB... very odd. Will keep updated! It could well be duff chips.
Countless reflows and checks but still not playing ball so I’ll leave it there. Guessing bad chips. I’ll remove them and maybe return to this one day.
Reply 21 of 45, by Thermalwrong
Perhaps look for any differences in resistors / capacitors around the chips between the 8mb and 12mb versions. I've been considering trying the same thing myself so I hope you succeed 😁
There's a similar thread here on a german forum:
http://extreme.pcgameshardware.de/tagebuecher … b-auf-12mb.html
Reply 22 of 45, by Thermalwrong
Now what I didn't say in my last post was that I bought those same RAM chips when you linked them, because I've also wanted to do this for a while.
I just tried soldering them on and it has taken *so long*. I should have cleaned the chips more, they are actually pretty difficult to solder to sell. Though I was just using a soldering iron, switching to leaded solder having quite poor results with the lead-free stuff.
The main problem I've found is that maybe the chip legs are at unequal heights? I should have checked them harder before going ahead. Anyways, once the isopropyl alcohol dries, I'll give a go with my card as well and report results.
Reply 23 of 45, by The Serpent Rider
Use S3 Virge or similar card to check if the RAM is dead.
Reply 24 of 45, by RichB93
All of the resistors are located identically. Got some super weird results so I'm chalking this up to bad RAM. Once removed the cards work fine again.
Yeah, this took my brother the best part of a day, so it's pretty disappointing that it didn't work! Once installed it bumped up to 6MB of RAM on one card and the other card the RAM detected went down and displayed as 3MB!
I think this is doable with a lot of patience, but be careful where you buy the RAM! I expect if I were to get donor RAM from a good card, this would've worked fine.
Reply 25 of 45, by Thermalwrong
I finally had a chance to test this out - the drivers show 4MB Frame Buffer and 8MB Texture Memory 😀 So now it's a 12MB card, thanks for the pointer to these chips!
I'll get some pictures of the card once I've tested it with a game and hopefully there won't be any texture corruption etc
Sadly, not really possible, I didn't install SOJ sockets, just soldered the chips directly. Even a single address / data line that's not connected or bridged will cause real problems with the memory, which might be why Rich is now seeing less memory than before the upgrade.
Reply 26 of 45, by anetanel
Thermalwrong wrote:
I finally had a chance to test this out - the drivers show 4MB Frame Buffer and 8MB Texture Memory :) So now it's a 12MB card, t […]
Where did you buy the memory chips?
And what card did you upgrade?
I'm looking into it as well. I thought of installing sockets too, but I don't think that there is enough room on my card (Diamond Monster 3D II).
Reply 27 of 45, by The Serpent Rider
Check them beforehand on S3 Virge.
Reply 28 of 45, by Thermalwrong
Okay, back with good news, the card works nicely and games work as they did before the upgrade.
The card itself is a generic 8mb reference design, probably a Pine or something similar, I couldn't see any branding on it other than 3Dfx:
1.99 MiB
I forgot to take any pictures of it before the upgrade because there are some good ones online already, but the front didn't change.
It now detects as a 12MB card in the driver's control panel:
316.44 KiB
The chips used can be found on thebay by searching for the part code in RichB93's original post. I think they are pretty old stock and were just loose in an anti static bag so I Recommend cleaning them and making sure the legs are equal height before proceeding. By getting them at an even height, and cleaning the chips and board, using solder paste, I expect they should go on properly without much trouble. I made the mistake of hand soldering these using my TS100 iron and an angled tip. It worked but it took a while before I was confident were no gaps or bridged pins.
1.33 MiB
See there's a gap at the top / front of the picture? While I was tinning and cleaning the pads, one of them fell off. Thankfully, this appears to be the only one that I could find that doesn't route anywhere.
1.61 MiB
I did find a few spots where under a microscope / zoomed macro camera shot, it looked like there were gaps between the SOJ chips and the pads - maybe they're okay underneath but I didn't want to take chances, so I even broke out the leaded solder and went over them until there was a clear join between the board and the chip.
1.67 MiB
So far, I've tested it with Unreal, Carmageddon 2 and glQuake, each of which works nicely - though I do get some HUD flickering in glQuake, I'm not sure what's causing that. I went from Voodoo 1 to TNT2 Ultra back in the day, I'm not as familiar with the Voodoo2
Reply 29 of 45, by AtTheGates
Weebob wrote:
RichB93 wrote:
Thank you. I did see that thread but it didn’t really get anywhere. Considering I’ve found a place that will do all the chips for just over £10, I figure it’s worth a go.
Yup, it just stops.
If you go ahead please please please update this one with any progress, I am very much interested in getting this done myself. I have my old diamond monster 2 8meg, I couldn't afford the 12meg at the time but it was the one I wanted.
I have an 8MB Diamond Monster 3D II. Even though 12MB doubles the texture memory, it doesn't improve performance. You'd probably be better off getting another 8MB card for SLI.
Reply 30 of 45, by bjwil1991
Good thing my STB BlackMagic VooDoo2 card has 12MB RAM.
Reply 31 of 45, by AtTheGates
On balance I'd rather get a Voodoo III. 16MB RAM, no 2D card needed, and around Voodoo II SLI performance.
Reply 32 of 45, by Thermalwrong
This was just a fun project / completionist thing for me - I have a Voodoo 1 now (yay!), 2x Voodoo 3 cards (in different PCs) and I am aware that the Voodoo 3 is roughly equal to a V2 SLI setup. So this upgraded Voodoo 2 is as good as it gets for the Voodoo 2 era, until I find another Voodoo 2 at a price I'm okay with paying. This memory upgrade cost about £12 + equipment and I paid around £35 for the card, I'm pretty happy with the outcome.
I have yet to notice a difference from its pre upgrade state, but I have bought a few too many computers to play with and don't really put much time into benchmarking right now.
I swear this game plays better in Glide renderer rather than D3D:
699.04 KiB
Reply 33 of 45, by bjwil1991
I also have a VooDoo3 3000 PCI (added a fan onto the heatsink) in my Socket 7 machine.
Reply 34 of 45, by The Serpent Rider
There's a huge improvement in late games like American McGee Alice. Some Unreal Tournament maps are too huge for 8mb cards too.
Reply 35 of 45, by AtTheGates
Thermalwrong wrote:
This was just a fun project / completionist thing for me - I have a Voodoo 1 now (yay!), 2x Voodoo 3 cards (in different PCs) an […]
It's a cool idea, but I'd be to worried about knackering the card. Voodoo II aren't cheap!!
Reply 36 of 45, by AtTheGates
That's texture swapping. No exactly more performance.
Reply 37 of 45, by Thermalwrong
It's easy enough to take the chips back off with a heat gun, then it's right back to where it started 😜
That's one reason I like working with this older PC stuff, no/few BGA chips to worry about.
Reply 38 of 45, by meljor
Very nice testing guys! So does this also mean that when a card has image corruption we can simply remove 4mb and see if it behaves after that with only 8mb?
And how about 4mb? does that work as well?
