Versamap Vmap Versa Map Charles Culberson
Having problems with a specific game or application? Post your problems here!
Postby Jens » 2018-8-07 @ 04:42
Hello!
I got different versions of the MWDB-II mapping-program Versamap (1992-95). V 1.1, 1.4 and 1.5 work fine. Versions 1.2 and 1.3 (look almost the same to me) can be started via batch under Win XP. In DosBox they crash & produce the following error:
Path not found in module MPROJECT at address 1DEA:0322
Why?
Greetings Jens
Jens
Re: Versamap Vmap Versa Map Charles Culberson
Postby Stiletto » 2018-8-07 @ 14:44
Moved to DOSBox Games/Apps.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby olddos25 » 2018-8-07 @ 15:09
Try vDosPlus and see if it works there, cause that is designed to work with applications which aren't games.
Currently mod on several Discord servs and a forum, so you can trust me if you want a DOSBox mod here!
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
olddos25
Postby Jens » 2018-8-07 @ 16:51
olddos25 wrote:Try vDosPlus and see if it works there, cause that is designed to work with applications which aren't games.
Well, i play with it, so it is a game. Versamap is simple 8-bit DOS, less than 400K, no long file-names, it runs on a 386 and just visualized a small database from 1980 = nothing sophisticated. Maybe Versamap is buggy (some versions work, others not). Otherwise i'm sure, i myself am doing something wrong and DosBox can handle it (like my uncounted games from 1980 to 1995, all 8bit-Windows versions and a bundle of geography/astronomy progs (games) that are a lot more complex than Versamap).
Thanks for your commendation, but the vDosPlus-guy asks for a donation on the very first page of his site, and i'm tired of beggars.
Anyway, thanks for your effort! Jens
Jens
Postby DosFreak » 2018-8-07 @ 17:12
There's nothing wrong with asking for donations for free software and it's not begging.
Did you install the software or are you trying to run an already installed copy?
Try it in real DOS using: pcem, vpc, vmware, virtualbox, physical computer
We don't care if the software works in the XP command prompt since that's not DOS.
User avatar
DosFreak
Postby Dominus » 2018-8-07 @ 20:04
Yes, path not found points at problems with the installation, e.g. preinstalled app and the paths don't match after mounting in DOSBox
User avatar
Dominus
DOSBox Moderator
Postby olddos25 » 2018-8-08 @ 19:14
I thought it was an app, sorry.
olddos25
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: Google [Bot] and 0 guests
