CPU storage
Announcements, advice, random banter, unrelated discussion, et cetera.
CPU storage
Postby the-beast » 2018-8-09 @ 18:48
Hi, long time lurker, first time poster. Hopefully doing more posting going forwards!
What do people recommend for storing PGA CPUs safely?
I can store come on motherboards but the rest are placed in pairs with the pins of each one placed together to try and avoid bending them.
Does anyone else know of any better ways of doing it? I've seen a few of these sort of things for modern CPUs on ebay https://www.ebay.co.uk/itm/50pcs-CPU-Clamshell-Blisters-Tray-Case-EPE-protection-pads-For-Intel-processor/131672209476?hash=item1ea8467844%3Ag%3Aq8UAAOSwwpdW4ocJ&_sacat=0&_nkw=cpu+clam+shell&_from=R40&rt=nc&_trksid=m570.l1313
Would these work with older CPUs (486s, pentiums, athlons etc?) Thought I would ask the community before I splash the cash on something that might not safely fit the CPU.
Thanks for the advice!
the-beast
Re: CPU storage
Postby Aideka » 2018-8-09 @ 19:20
It works with old CPUs if they are of the same size as those supported ones, which mostly means not compatible. I just use a wooden box with the CPUs stacked on top of eachother, not preferable surely, but since I very rarely move that box anywhere the pins stay ok and yet not a single broken CPU in the 12 years I have been doing it.
User avatar
Aideka
Re: CPU storage
Postby the-beast » 2018-8-10 @ 18:41
I suppose my main fear is if I move/knock whatever they are stored in damaage them that way. I have been known to drop things from time to time. :(
I'll take a look at the boxes I have, maybe I can put some padding.
Thanks
the-beast
Re: CPU storage
Postby Aideka » 2018-8-10 @ 20:13
Hmm, maybe some kind of a wooden box with antistatic foam between the CPU layers would be a good option. The box would be sturdy enough to withstand minor drops and the antistatic foam between layers of CPUs would further soften the blow in case it falls or some other mishap happens. The foam would also remove the possibility of the pins scratching the CPU underneath.
User avatar
Aideka
Re: CPU storage
Postby the-beast » 2018-8-12 @ 07:51
Sounds like a good idea. I'll see what I can knock up.
the-beast
Re: CPU storage
Postby bestemor » 2018-8-12 @ 21:34
I have been using these things, which fit most CPUs, and you can actually put 2x safely inside - 1 in between the 2 pink pads , and the second CPU on top of the upper pink pad...
(both cushions are loose, not glued, at least on those I bought, but ask seller just in case)
Should survive many drops before they dissolve... :D
https://www.ebay.co.uk/itm/10x-CPU-Processor-Packaging-Storage-Box-With-Anti-Static-Foam-Protection/312133685912
User avatar
bestemor
Re: CPU storage
Postby shamino » 2018-8-13 @ 14:58
Several years ago I bought a bunch of CPU trays on eBay. They stack and they keep the CPUs very safe. At the time it was rare to find trays for sale, so when some came up I jumped on them. I have something like 10 trays for PGA (most still empty) and 2 trays that were designed for mPGA478.
I did a quick search on eBay and there's a lot more listings for CPU trays nowadays. It seems the popular design now has an open area for the pins, which might make them more widely compatible. On mine the trays have a bottom but they're designed for the PGA pin layout to fit securely. My 2 mPGA478 trays do have open bottoms though.
This leaves Pentium Pros and slot CPUs. I imagine trays must have existed for Pentium Pros, but I've never seen one. I put the Pentium Pros in a foam lined box and the slots are piled up in boxes. I love how robust slot CPUs are.
User avatar
shamino
Re: CPU storage
Postby Errius » 2018-8-13 @ 15:17
Foam-filled boxes are best, but they're expensive for whatever reason.
"I damn near killed an idiot who insisted on commenting in Klingon, but only on bits of inline assembler embedded in C ..."
User avatar
Errius
Return to Milliways
Who is online
