Win98SE Loading Unusually Slow
Getting old software/games running on older hardware.
Postby PKFreeZZy » 2018-8-09 @ 21:06
Just recently, my retro PC started loading really slowly. Normally it'd spend 10 seconds on the cloudy "Windows 98" loading screen then 3 seconds in the DOS prompt before the desktop appears. All of a sudden it's taking over 30 seconds after a fresh install and have no idea what's happening. I even fiddled with my BIOS to see if I could fix it, no luck. Any help?
My Windows 98 PC: Slot 1 Pentium III 600EB|384MB PC133 SDRAM|32MB Leadtek GeForce2 Pro 5.5ns|Creative SB16 CT2230|COMPAQ Intel PRO 10/100Mbps|20GB Seagate Barracuda ATA IV|Linkworld LPD6-350W|Tekram P6Bx-A(n) Rev. 1.06
PKFreeZZy
Re: Win98SE Loading Unusually Slow
Postby oeuvre » 2018-8-10 @ 13:20
Could it be the hard drive failing or getting bad sectors?
NetVista Sleeper i7 3770, 16GB, GTX750, 2xSSD + HD, XP/7/MacOS 10.13.6
ThinkCentre Sleeper Ryzen 7 2700, 32GB, RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby mrau » 2018-8-10 @ 18:21
check DMA and disk health?
mrau
Postby derSammler » 2018-8-10 @ 18:30
Do you have an Ethernet card installed and no cable connected? That's the most common reason for slow booting of Win95/98, as it waits quite a bit for a DHCP server to answer, not knowing that no cable is attached to the Ethernet card.
derSammler
Postby PKFreeZZy » 2018-8-12 @ 05:36
derSammler wrote:Do you have an Ethernet card installed and no cable connected? That's the most common reason for slow booting of Win95/98, as it waits quite a bit for a DHCP server to answer, not knowing that no cable is attached to the Ethernet card.
Could've been that, as my ethernet cable is pretty loose, though even after properly connecting it, things didn't change. It seems it was a BIOS problem in the end as reverting to the defaults and then reconfiguring it made it go away.
PKFreeZZy
Postby Roman78 » 2018-8-16 @ 09:02
In this case W98 is querying the DHCP server and waiting. Could be speed up when set to Static IP instead of DHCP. In this case, even when the cable is lose, the PC boots fast.
Roman78
Return to Software
Who is online
