First post, by peido
Hi,
Yesterday I went to a computer store to buy thermal pads.
After paying, I asked them if they had any old computer going to the trash and they gave me this strange laptop:
125.85 KiB
1.23 MiB
Inside it says 'LEO' (I don't know if 'LEO' is the brand or something else) and it has a logo similar to Peugeot's logo:
1.23 MiB
On the bottom there are several labels, one of them says it's a model 'CEDAR':
1.35 MiB
1.37 MiB
I can't find any information online (besides a similar laptop on ebay and another similar laptop on youtube).
I haven't test it yet, because I don't know what's the power rating. One of the stickers on the bottom says '9-30Vdc, 5-1.5A', but I can't decipher this information. Should I use 9V or 30 V? 5 A or 1.5A? Center tip positive? If anyone can help I would appreciate.
Also, anyone that knows more about this brand/model, or anyone that has drivers, manuals, anything, please let me know.
Thank you.
EDIT: changed title of this thread to add a more correct name of this laptop.
Reply 1 of 5, by stamasd
based on the FCC ID it's a laptop made by FIC in 2002: https://fccid.io/EUN
And this post identifies it as a FIC 5220CDT: https://www.treiber.de/forum/thema/21317/Bios-FIC-5220CDT/
More info: F.I.C. DESIGNote 5220CDT Pentium MMX, 32MB RAM https://picclick.co.uk/FIC-DESIGNote-5220CDT- … 3402979141.html
There's also a PDF about it here: ftp://ftp.algo-hk.cz/MIRRORS/ftp.fic.com.tw/n … AQ/faqs5200.PDF but I can't access it because FTP is blocked in my current location.
Happy searches. 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 2 of 5, by AlaricD
A wide range of voltages, with correspondingly lower amp requirements as voltage increases (5A at 9V, 1.5A at 30V, which is the same nominal 45VA. At 10V it may draw 4.5A; at 25V it may draw 1.8A). The polarity may be shown at the power jack itself, embossed in the plastic.
"The Big Bang. The ultimate hero of low frequency. The divine intergalactical bass drum connecting the tribes of our solar system."
Yello
"Solar Driftwood"
Reply 3 of 5, by peido
Thank you so much to both of you, you really helped me 😀
stamasd wrote:
based on the FCC ID
I did not know I could search the FCC ID to find out more about a computer, always learning.
Looks like F. I. C. stands for First International Computer.
I tried 19V (can't remember A, but it was enough), the polarity wasn't shown so I chanced centre tip positive and it worked.
164.01 KiB
It has Windows 98:
145.67 KiB
But looks like the HDD has problems, it stopped in the AntiVirus before starting Windows:
201.89 KiB
I'll try to make an image of the HDD (to save any drivers or software related to this laptop), then I'll try to find what's wrong with the HDD.
Anyway, I'm extremely happy that it works.
It has one of those horrible BIOS/CMOS batteries, it started leaking and doing nasty stuff:
145.55 KiB
I removed it before doing more damage. More information in Warning: Leaking BIOS/CMOS/Resume Batteries Damaging Laptops.
The screen hinges are also broken, I'll try to find a solution to that.
Reply 4 of 5, by AlaricD
You're welcome!
So, it should use about 2.37A at that voltage. Guess the 50/50 chance paid off (I'd hazard to say that pin-positive would have been the default just because that helps keep the + side from being exposed on the barrel plug).
At least it found 0 viruses!
Looks like you're on your way to some retrocomputing satisfaction!
Yello
"Solar Driftwood"
Reply 5 of 5, by stamasd
stamasd wrote:
based on the FCC ID
Searching by FCC ID is key to identifying many kinds of hardware. Have an unknown card, drive etc? The FCC ID will at least give you an idea of the manufacturer and type of device so you can narrow further searches.
I/O, I/O,
I/O, I/O
