First post, by Intel486dx33
Building the Ultimate Audio / Gaming computer.
It took me about 6 months to gather up these parts.
My first original build I found to be under powered for Win-XP so I upgraded the motherboard, CPU and ram.
This computer was really easy to build and setup with MS-Windows-XP , OEM drivers and WinXP provided drivers.
First Original Build Specs 2018-8-25 Motherboard - Intel P4 - D850GB - Socket 423 Motherboard manual - https://webdoc.lenovo.com […]
2018-8-25
Motherboard manual - https://webdoc.lenovo.com.cn/lenovowsi/cskb/d … NVjMQ3toDsr.pdf
CPU - Pentium-4 -1.5ghz.
CPU Cooler - Intel
Memory - 512mb. ram
Hard-drive - 160gb 72,000 rpm IDE
Graphics - Asus Nvdia Geforce 4 Ti4200, AGP
Audio:
Sound Blaster Audigy 2zs
Terratec DMX6 Fire 24/96
Terratec EWS88-MT
Terratec EWX 24/96 with SPDIF
DVD - Pioneer
Case - Flower 201 - Black stainless steel with Clear side panel.
Operating System - Windows XP
Upgraded Build Specs 2018-9-7 Motherboard - Asus P43T-ES3G Motherboard manual - https://www.gigabyte.com/Motherboard/GA-P43T-ES3 […]
2018-9-7
Motherboard manual - https://www.gigabyte.com/Motherboard/GA-P43T-ES3G-rev-10#ov
CPU - Intel Core-2-Quad Q9300 @ 2.5ghz ( 4-cores, 4-threads ).
CPU Cooler - Zalman
Memory - 2gb. ram
Hard-drive - 250gb 72,000 rpm IDE , Seagate.
Graphics - Nvidia PCIe
Audio:
Terratec EWS88-MT
Turtle Beach - Aureal Vortex-2 8830 with SPDIF. ( PCI )
Yamaha XG YMF-724 ( PCI )
Realtek Audio ( Onboard )
DVD - Pioneer
Let me know in your comments how I can make this build better as a audio / gaming computer.
I really like this choice of audio cards. They have good clear sound, treble and bass.
Thanks.
Photos taken with my 2017 iPad.
    1.27 MiB
    1.28 MiB
    910.9 KiB
    972.63 KiB
    959.54 KiB
Reply 1 of 53, by Intel486dx33
More photos
    165.95 KiB
    1.43 MiB
    1.28 MiB
    150 KiB
Reply 2 of 53, by Intel486dx33
More photos
    86.24 KiB
    86.67 KiB
    143.52 KiB
    184.65 KiB
Reply 3 of 53, by Intel486dx33
More Photos:
    21.14 KiB
    42.44 KiB
    552.5 KiB
    57.43 KiB
    24.03 KiB
Reply 4 of 53, by Intel486dx33
More photos:
    143.46 KiB
    34.44 KiB
    43.05 KiB
    38.76 KiB
Reply 5 of 53, by Intel486dx33
More photos:
Reply 8 of 53, by chinny22
What do you mean better?
Whats the video card and what games are you playing?
Depending on those answers maybe a better graphics card, but if it playing everything nicely then it doesn't really matter.
Rounded floppy and 80 pin IDE cables? makes the inside look better?
But really its a pretty good build already 😀
Reply 10 of 53, by Intel486dx33
chinny22 wrote:
What do you mean better? Whats the video card and what games are you playing? Depending on those answers maybe a better graphics […]
Yeah, I did not tie up the cables very good because I wanted to make sure everything worked first.
I will have to go back and perform better cable management.
Reply 11 of 53, by Intel486dx33
gdjacobs wrote:
Not sure of the reason behind two Envy24 based cards.
You are right, I added the second card for toslink support but the DMX 6fire also has toslink support in the drive so I don’t need the other card.
I can remove the EWX 24/96 card and maybe add a PCI card with Yamaha OPL support.
What card can you recommend ?
Reply 13 of 53, by gdjacobs
Intel486dx33 wrote:
You are right, I added the second card for toslink support but the DMX 6fire also has toslink support in the drive so I don’t ne […]
Depends what you want. A Yamaha YMF-7x4 PCI would be good for DOS games and OPL support, but a Vortex 2 would be better if you want A3D support.
Reply 14 of 53, by Intel486dx33
Okay, Yeah.
I have a Vortex-2 PCI lying around somewhere. I was thinking maybe a Yamaha XG PCI.
I need cards that are Win2000 compatible.
Reply 15 of 53, by JidaiGeki
Intel486dx33 wrote:
Also
Does any know what Video card this is ?
Quick Google says it's an Asus V9280/64M Geforce 4 Ti4200, AGP not PCIE 😉
By the way, I might be mistaken but I think the Terratec DMX 6fire sound module has a wavetable connector in the front connector box - I used mine with a Korg DB once upon a time. Should be easy to take the top cover off to have a look.
Reply 18 of 53, by Intel486dx33
Poulton wrote:
Intel486dx33 wrote:
Then I can replace it with a Voodoo-3 AGP.
The motherboard doesn't have an universal or 3,3V AGP Slot. So it will not fit.
What do you think?
I can replace the motherboard with an Asus P3 1ghz with APG then I can use a Voodoo-3.
Is it worth it or should I just keep this motherboard ?
I want to be able to play the most variety of PC games.
Reply 19 of 53, by Intel486dx33
More Photos for you non-believers.
Currently running WinXP-Pro and all the TerraTec default drivers load just fine.
I plan on swapping out the motherboard for an Asus P3, 1ghz. later and Installing Dual boot Win-2000-Pro and DOS and upgrading to an SSD.
Just slapped this together real quick to make sure everything works. And it does.
Runs steam too.
    1.66 MiB
    1.86 MiB
    561.56 KiB
    1.64 MiB
    1.11 MiB
