AUDIO Patch supporting FLAC, Opus, and MP3 audio tracks
Here you can discuss the development of patches.
Re: AUDIO Patch supporting FLAC, Opus, and MP3 audio tracks
Postby Qbix » 2019-5-06 @ 11:33
I commited as is and then a little change, as not all compilers that we use, support the c++11 array bracket in constructors. I hope the new code is fine as well
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby krcroft » 2019-5-06 @ 20:54
Right on QBix; testing continues with the latest builds containing this update, and all are free from valgrind memory issues. Cheers!
User avatar
krcroft
Postby Yesterplay80 » 2019-5-08 @ 08:53
krcroft, do you have an updated patch? Version 9 of your patch doesn't apply any longer after r4223.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby krcroft » 2019-5-08 @ 23:39
Yesterplay80 wrote:krcroft, do you have an updated patch? Version 9 of your patch doesn't apply any longer after r4223.
Yesterplay80, thanks for the heads up. Sync'd up patch is posted (download)
User avatar
krcroft
Postby Yesterplay80 » 2019-5-09 @ 08:48
Great, thank you! A new build of ECE is released as well.
User avatar
Yesterplay80
Previous
Return to DOSBox Patches
Who is online
cron
