First post, by Demonslayer2103
480.36 KiB
Io shield
Hello I'm a bit new to vogons did I few posts a while ago but not much more then that anyway im looking for a socket 370 motherboard with 1 or 2 isa slots 3 to 4 pci slots built in audio and gameport and onboard lan I don't need a agp slot as I have a voodoo 3 3000 pci I got for $15
It also needs to fit in the io shield I have already I will upload I picture of I io shield but its pretty standard io from the time
Reply 3 of 25, by stamasd
Here are a few examples with Via Apollo 133A chipset:
ECS P6BAP-A+
Gigabyte GA-6VX7-4X
Abit VH6T (Apollo Pro 133T, supports Tualatin)
etc.
Most don't have onboard LAN but that's an easy fix with a PCI card.
In fact I will direct you to this list:
https://www.vogonswiki.com/index.php/List_of_ … 70_motherboards
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4 of 25, by Demonslayer2103
I had looked at the list but they do not specify if they have onboard lan the only one on there is the qdi Advance 6T and I cant find one for a good price online I want it to have onboard lan and not a pci card
Reply 5 of 25, by stamasd
The Advance 6T has several versions, only the A6T-L version has onboard LAN AFAIK. Also QDI motherboards are pretty rare. I have a few QDI motherboards and they were a pain to find. Finding a specific revision of a rare motherboard from a relatively obscure manufacturer will be a bit like finding a needle in a haystack.
Also the A6T-L is a mini-ATX motherboard with only 3 PCI and 1 ISA slot (of which one PCI is shared with the ISA, so maximum 3 cards possible, either 2PCI+1ISA or 3 PCI at one time). No AGP.
I/O, I/O,
I/O, I/O
Reply 6 of 25, by Demonslayer2103
I really only need 2 pci slots and 1 isa slot I have a voodoo 3 3000,usb 2.0 pci card and a awi 64 value isa in the build but I am thinking of adding one more pci card do you happen to have the board
Reply 7 of 25, by stamasd
No, I don't have this particular model.
I/O, I/O,
I/O, I/O
Reply 9 of 25, by stamasd
Nope. Personally I'd find one of the larger motherboards and stick a PCI LAN card in it, but that's just me. Socket 370 motherboards with ISA slots will be in this day pretty hard to find anyway.
I/O, I/O,
I/O, I/O
Reply 10 of 25, by cyclone3d
I think you are going to be pretty hard pressed to find a board for a good price with all those features unless you drop the onboard LAN requirement.
Here is one, but it is $75 + shipping.
Didn't see any others on eBay at the moment.
https://www.ebay.com/itm/Mainboard-PCChips-So … nd/153165524277
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 13 of 25, by debs3759
I found one finally https://m.ebay.com/itm/EliteGroup-Computer-Sy … S-/142688735492
But does it support Tualatin?
I wouldn't buy that, even at that price, as it is missing one of the points for attaching a heatsink (unless you have a heatsink that will still fit)
Reply 14 of 25, by stamasd
It appears to use a SiS630 chipset http://www.motherboard.cz/mb/ecs/P6STM.htm so AFAIK no it doesn't.
I/O, I/O,
I/O, I/O
Reply 15 of 25, by Demonslayer2103
30.4 KiB
Cpu cooler
Will that motherboard allow me to use all the pci and isa slots or is the isa slot shared with a pci slot also will this cpu cooler still be able to mount on there
Reply 16 of 25, by oohms
You know you can swap IO shields right? If you really wanted to keep the case, I would sell or swap the voodoo 3 for an AGP version, get a micro atx board with AGP and ISA and that comes with an IO shield and buy a pci network card
Then maybe you can find the rare micro atx board that does both tualatin and ISA
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 17 of 25, by Demonslayer2103
The case can take up to full atx I just cant find a motherboard that has what I need that's not micro atx
Reply 18 of 25, by PC Hoarder Patrol
Unless you're into re-capping it, I'd avoid this as the ones round the cpu socket look blown to me
Reply 19 of 25, by cyclone3d
Why do you "need" onboard LAN?
What happens if the onboard LAN is flakey, buggy, or bad? Then you have to use an add-on NIC anyway.
And if you are planning on using it for DOS games, you really don't want onboard sound either except for a few select ones and that is going to make your search even more impossible.
YMF7x4 Guide
