First post, by tegrady
Hi, I bought a cheap-o computer case to do a Windows 98 build in.
The case is missing spots for two standoffs that I need for my motherboard. There is no standoff hole dead center of the board or in the upper right corner, which is the most concerning.
Would plastic spacers / standoffs like these work to help support the board? Are these plastic spacers/standoffs a standard size? I can get them cheap on eBay, but I want to make sure they will fit.
Thanks.
This is what I am talking about:
    13.88 KiB
Reply 1 of 2, by cyclone3d
Those come in a couple different lengths. They also used to come with some cases, both with, and without the threaded portion.
I have used the plastic standoffs without threads before, but it is not really the best way to go about it.
If it were me, I would just drill and tap holes in the case where you need them and use standard standoffs.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 2, by tegrady
I only need them for 2 out of 7 mounting holes on the motherboard so if they fit, I don't see a problem. Also, the mounting spots that the case does have for standoffs are slightly raised. Therefore, if I just drilled a hole into the case, that hole would be lower than the rest of the holes and the standoffs would be at different heights, which would not work.
Just looking at the plastic spacer, it seems like it should work, but I can't really tell until I have it in hand. As I can get 10 of them for less than $2 shipped on eBay, I think I'll just take the risk...
