First post, by gryffinwings
Does anyone know of any coolers that could be used for the hotter AMD Socket A/462 CPUs? I'm doing basic searches on eBay and such, but I have not had much luck in this.
At the moment, the only thing I can think of is replacing the 60mm fan with a Noctua fan, as far as I know, this cooler is a Coolermax model. Thoughts and recommendations are as always much appreciated.
Please do not worry about the jumbled mess, I have since cleaned and tidied the insides of the case.
41302538_1847674011936267_6936719250757255168_o.jpg?_nc_cat=0&oh=e1f2130285e7a9213c018ffc29b5b235&oe=5C1F564D
Main Computer: Custom - Intel 12900K, Asus Nvidia 3080 Ti, 64 GB DDR5.
Retro Computer: Packard Bell Legend I - AMD 286, 640KB RAM
Retro Computer: Dell Dimension 4400 - Pentium 4 2.8 GHz FSB 400 MHz, ATi Radeon 9600XT, Sound Blaster Live!, 768 MB RAM.
Reply 1 of 10, by gdjacobs
These are good.
https://www.anandtech.com/show/825/6
Of course you could go gonzo (complete with a Delta "electric tornado" fan)
https://www.anandtech.com/show/825/4
Reply 3 of 10, by cyclone3d
Those Alpha pin coolers suck big time. I had one back in the day. Piece of trash it was.
The thin copper fin one is a bit better, but for great cooling you want a cooler with heatpipes.
The Thermaltake Silent Tower was the very first heatpipe cooler I bought. The only bad thing about it is the way the stock mounting hardware works. You really need to use nylon nuts on the motherboard side as the stock setup just has the bolts go through the board and directly to the bracket that hold the cooler on place. It doesn't work very well that way.
As soon as you add the nylon nuts on the motherboard side, the stability is rock solid.
http://www.silentpcreview.com/article201-page1.html
The Big Typhoon and Big Typhoon VX are pretty much the best you can use without modification and they work extremely well. They use the same exact mounting hardware as the Silent Tower.
The only difference the VX has, it that is comes with a higher CFM/more blades fan but you can put whatever 120mm fan you want on there so it really doesn't matter.
https://www.techpowerup.com/reviews/Thermaltake/BigTyphoon/
Edit: With either of these coolers you will want one of those copper shims to help protect the CPU die when mounting the cooler. I use one on my socket-A builds no matter what cooler I am using.
I also opted for nylon wing-nuts to tighten down the retention bracket instead of using the dumb tiny metal nuts. It makes it way, way, way easier and they won't come loose either.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 10, by gryffinwings
cyclone3d wrote:
Those Alpha pin coolers suck big time. I had one back in the day. Piece of trash it was. […]
The question now is where the heck would you find these coolers, I haven't seen them anywhere.
Reply 5 of 10, by gdjacobs
Heatpipe coolers usually weren't available for socket 462, although definitely go for one if that's an option and it suits your genre.
The Thermalright SI-97 is probably better. I've always disliked Thermaltake going back to the GOrb days. They're the poster boys of form over function.
Reply 6 of 10, by Unknown_K
The all copper Thermaltake I snagged back in the day worked fine and still works for me.
Looks like this:
23.44 KiB
Reply 8 of 10, by gryffinwings
Looks like this:
That would be pretty sweet. Gotta find one though.
Unknown_K wrote:
Have you taken the fan off and cleaned the heatsink fins?
Yes, that I have done and applied new Arctic MX-4 thermal paste. I just don't think it will be sufficient for a higher spec Athlon XP 2400+ or 2600+ being an all aluminum construction.
Reply 9 of 10, by cyclone3d
There are 4x Big Typhoons / VX on eBay right now and a few more if you search just by the model numbers.
https://www.ebay.com/sch/i.html?_from=R40&_tr … yphoon&_sacat=0
There is one Silent Tower on eBay right now:
https://www.ebay.com/itm/Thermaltake-CL-P0025 … an/182439127729
I still have mine back from when I bought them new.
Here is another option - made by MGE ???
https://www.ebay.com/itm/New-Sub-Zero-K7-CPU- … ng/372429301540
YMF7x4 Guide
Reply 10 of 10, by cyclone3d
The Silent Tower and the Big Typhoon / Big Typhoon VX were pretty much the best coolers available when they were released.
Yes, the golden orbs were trash, but the heatsink tech back then was pretty horrible for the most part.
The crazy Alpha coolers with the make your ears bleed fans were considered the best back when they were available, but they really were trash. The ONLY reason they cooled anything was because of those crazy fans.
Once thin-fin stuff came out, it was a lot better than the older, crappier designs. Then when heatpipe stuff came out it was game-over for everything else.
I worked at a computer store back when the Silent Tower was released. It was the bomb diggity. They also had a version with copper fins but it weighed a ton and cost a decent amount more so I never got one.
There was another cooler that Thermaltake made that was meant for Socket 939, which I also still have.. but it was meant to be able to be used without a fan. Really sucked without a fan, and was just-ok-ish with a fan.
Then I got the Big Typhoon. I used it all the way up to, and including, my first LGA 1336 build with an i7-920 (with a modified mounting system). It would only cool good enough for it to run up to about 3.6Ghz, so that is when I upgraded to a Noctua NH-D14.
YMF7x4 Guide
