Fun with Tape Drives ...
Reply 20 of 22, by CarlHopkinsUK
CarlHopkinsUK wrote:
Ugh Travan.... How are your tapes holding up? I had the pleasure of doing a data analysis on 4x unknown Travan tapes for my work last week...3 out of the 4 had broken internal belts (for those of you unfamiliar with Travan, belts are inside the tape!) And these where newer 20/40gb versions from 2003...
DAT/DDS in the little tapes and LTO in the big where always the best...
On the plus side tho i do get to keep the lovely new Certance/Seagate Travan Drive, that was used just for this...seeing as we have nothing at work with an IDE connector on it (even my recovery rig uses a IDE>SATA bridge), may be of some use if i grab some NOS tapes i guess.
221.46 KiB
219.35 KiB
Not related to that job, but on the subject of Tapes and backup libs, found this in my drawers last week. Seagate BackupExec, for NT, Netware, and OS/2 Server! Does anyone know if this is related to the later Synatec version?
192.78 KiB
