GOG Blood One Whole Unit + Glidos + WinXP32
General information and assistance with GliDOS.
Postby buckeye » 2018-9-28 @ 12:05
I downloaded the Glide/Blood exe file and installed it but not sure if I did it right. I already have the GOG version, was I supposed to install it in that directory or keep it separate per the default?
It works ok, maybe I'm expecting too much but still looks "rough" but probably need to tweak some stuff. Can anyone recommend some settings that might help? Running it per the "dosbox" toggle within Glidos.
Foxconn Q45M E8400 Core2 Duo 2GB DDR2 800 160GB BFG Geforce 7950GT 512MB 500W XP SP2
Asus P3B-F P3 850 512MB 40GB Hercules 3D Prophet II 64MB Voodoo2 SLI Aureal Vortex 2 400W 98SE
User avatar
buckeye
Re: GOG Blood One Whole Unit + Glidos + WinXP32
Postby Kerr Avon » 2018-10-15 @ 19:47
What I *really* recommend is that you use the Java-built game engine semi-port at:
https://m210.duke4.net/index.php/downloads/download/8-java/50-bloodgdx
It's called BloodGDX, and it is amazing, being basically a Windows port of the game engine, so it runs the original game but with all of the advantages you'd expect of a modern Windows port, such as higher resolution support, proper mouse support, easier key binding, and so on, all from the one program.
The same bloke is also working on a game engine port for Redneck Rampage, Tekwar, Witchaven, Duke Nukem 3D, and Shadow Warrior 3D, though he's not released a version for the last two games (DN3D and SW3D) yet.
Kerr Avon
Postby buckeye » 2018-10-16 @ 14:54
Kerr Avon wrote:What I *really* recommend is that you use the Java-built game engine semi-port at:
Thanks Kerr Avon, hopefully it'll work with XP SP2. I'll post what I find out here when time allows.
User avatar
buckeye
Postby DosFreak » 2018-10-16 @ 15:00
IIRC, it requires Java 6+ and I think Java is still compatible with XP up to 8 Update something so you should be good.
User avatar
DosFreak
Return to GliDOS General
Who is online
Users browsing this forum: No registered users and 0 guests
