First post, by superfury
Apparently, you can JMP to a call gate, but it doesn't save any return information? It's safe to do with task switches(which can't iret to the previous task because it's a JMP, but when using JMP to call a function, why would you want to do that? Unless you have far return data on the stack already?
UniPCemu Git repository
