The great Pentium Pro haul of 2018
Reply 60 of 169, by liqmat
bjwil1991 wrote:
I had that SCSI RAID card that was in a Dell PowerEdge 6300 server, and I used it in my K6/2-300 system until I killed the card when I was updating the BIOS (never do that). I still have the RAM and the battery pack.
I wonder if somehow I could dump the BIOS for you and you could reflash?
Reply 61 of 169, by luckybob
You would likely need to remove the flash chip located to the right of the Nvram block. Has a "0132" on the sticker.
Reply 62 of 169, by bjwil1991
The cards went to the big computer part in the sky sadly. And this was years ago (2013-2014).
Reply 63 of 169, by liqmat
Will be peeking inside these tonight from the haul. There is a tad bit of surface rust on the bottom of the cases, but nothing breaching the metal. Luckily there are quite a few boxed caster wheels for these cases in the lot so I will be using those.
1.02 MiB
998.85 KiB
Reply 65 of 169, by bjwil1991
Ah, SCSI hard drives. The sound of 10K-15K RPM drive waking your whole household and neighbors. I have 3 Seagate 73.4GB 15K Ultra SCSI 320 and 2 Compaq/Fujitsu 18.4GB(?) 10K Ultra SCSI 160 drives that I pulled from the PowerEdge 6300 server (still have them and they've been in storage for years now). I remember doing a RAID5 on all 5 drives in case one of the drives stopped working, at least it'll retain the data on the other 4 drives.
Reply 67 of 169, by xjas
Interesting CD-ROMs up there. I squinted at the one on the right for a while trying to figure out it it was a Panasonic CR-563, but it looks like it's just a close design. I'm guessing it's a SCSI drive anyway; I assume there's no sound card in the system to hang a 563 off.
Those cases look WAY smaller with the doors open so you can see the size of the drive bays. 😜 Closed up they look like full-on server racks. How tall are they?
Reply 69 of 169, by liqmat
So from left to right.
1.) Pentium 100
2.) Pentium Pro 200
3.) Pentium 100
4.) Pentium Pro 200
5.) Dual Pentium Pro 200
Most have SCSI CD-ROM drives and basic Trident ISA video cards.
Lots of SCSI drives of course.
Reply 70 of 169, by bjwil1991
*whistles in appreciation* Noooooooiiiiiiiice!
Reply 73 of 169, by chinny22
liqmat wrote:
I think these were used as basic file servers from the company they came from.
Have you fired them up? I'm thinking you'll need ear plugs with all those drives going at once!
Reply 74 of 169, by liqmat
liqmat wrote:
Mmmmm... minty fresh! Found this in a box.
1.45 MiB
Sadly I get nothing but screen garbage (random colored ASCII characters) all over the screen at post. I then gave it a good scrub with alcohol and a soft bristle toothbrush. It then posted normally, but after a few more reboots it went back to screen garbage again.
Reply 77 of 169, by bjwil1991
Could be dried out capacitors, or a cold joint somewhere, but, that's just my $0.02
Reply 78 of 169, by liqmat
I agree with you, but this card has such tiny capacitors that even with my nice solder station I don't trust myself in the world of tiny soldering. I can do the larger caps all day long, but my hands aren't steady enough for the tiny ones.
