DOSBox SVN bug: Lemmings and Oh No! More Lemmings crashes after finishing a level and wanting to continue
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby olddos25 » 2018-10-13 @ 16:37
Well, I encountered this bug recently. In Lemmings and Oh No! More Lemmings (using the CD version BTW) when you finish a level, you have the option to continue to the next level or to return to the title screen. If I choose to be taken to the title screen, I go to it, and then the game hangs.
If I choose to continue to the next level, it still takes me back to the title screen to then hang! Newer versions are supposed to solve problems, not originate new ones! Because I then tried with the 0.74-2 release and that doesn't happen. Can it get fixed? Thanks beforehand!
Currently mod on several Discord servs and a forum, so you can trust me if you want a DOSBox mod here!
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
olddos25
Re: DOSBox SVN bug: Lemmings and Oh No! More Lemmings crashes after finishing a level and wanting to continue
Postby dr_st » 2018-10-14 @ 11:27
I think if you click the mouse again or press Esc or some other key on the keyboard it might unfreeze.
User avatar
dr_st
Postby olddos25 » 2018-10-14 @ 14:17
Tried those things to no avail. It just doesn't respond to anything, neither keyboard buttons or mouse buttons.
olddos25
Postby Qbix » 2018-10-14 @ 15:50
do you use the same sdl.dll with both versions ?
Some SDL.dll versions generate extra mouse button press events, which lemmings doesn't like.
Not sure if this is the case for your problem though
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby olddos25 » 2018-10-14 @ 22:16
Nope. Neither with DOSBox 0.74-2 or DOSBox SVN. The thing is, I originally discovered this problem in DOSBox ECE. And I said to myself, "maybe the patches are causing problems". And the rest is history.
olddos25
Postby olddos25 » 2018-10-17 @ 19:34
Update: I recently discovered that when I press the right mouse button with the title screen locked up, it unfreezes for some reason. And then I can continue to the next level like normal. That's neat, but a little strange...
olddos25
Postby Qbix » 2018-10-17 @ 19:51
but which sdl.dll are you using with the SVN ?
User avatar
Qbix
DOSBox Author
Postby olddos25 » 2018-10-17 @ 22:35
With DOSBox SVN and ECE I am using version 1.2.15.0. i don't know what else you want me to specify tho.
olddos25
Postby Qbix » 2018-10-18 @ 06:37
and how does it behave if you use the sdl.dll from 0.74-2 with it ?
User avatar
Qbix
DOSBox Author
Postby Yesterplay80 » 2018-10-18 @ 12:30
I just downloaded the game (for testing purposes only!) but couldn't confirm your problem, even with the SDL.dll coming with ECE. Would you please post your .conf file, maybe it has another reason? Do you run DOSBox under Windows or Linux?
Btw.: What makes you think the game has frozen? Because you can't see a mouse arrow? Are the Lemmings at the bottom moving? Can you choose the options with the F-keys?
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby olddos25 » 2018-10-18 @ 14:59
Qbix, I will test that once I get home.
Yesterplay, I am on Windows and I don't think the conf file is the problem. I'll post a screenshot when I get home.
olddos25
Postby olddos25 » 2018-10-21 @ 02:43
Qbix, if I use the SDL from DOSBox 0.74-2 on SVN, it lets me continue. Like, it doesn't go to the title screen to then "freeze" but it goes to the summary screen of the next level.
Yesterplay, it looks more or less like this:
The Lemmings at the bottom of the screen don't move, there normally isn't an arrow on the screen, so I can't see it, and I can't trigger things with the function keys. So yeah, it is frozen.
olddos25
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 3 guests
