HELP WITH SOUNDBLASTER X-FI MIDI
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby bionicle_159 » 2018-10-14 @ 00:05
I've purchased an old 2006 X-Fi with the classic Soundblaster front panel and of course straight after LGR posted a video on it - pointing out the proprietary mini-din connector for MIDI devices!
I would really appreciate someone to do a simple write-up of the pin-out as this would save myself a big headache with dealing with eBay sellers, as the prices for the adaptor cables are annoyingly high on eBay UK for what is essentially a simple wire conversion.
bionicle_159
Re: HELP WITH SOUNDBLASTER X-FI MIDI
Postby Salient » 2018-10-14 @ 08:35
I measured my own cable and came up with this:
Male mini DIN:
Female DIN end:
I only use the MIDI out of my X-Fi so I am not totally sure if the other conversion cable could be different but as I recall it, they are both the same and not specifically labeled for MIIDI IN or MIDI OUT.
User avatar
Salient
Postby bionicle_159 » 2018-10-14 @ 13:53
so are the blank pins ground?
bionicle_159
Postby Salient » 2018-10-14 @ 14:08
bionicle_159 wrote:so are the blank pins ground?
Blank pins are not connected anywhere.
User avatar
Salient
Postby bionicle_159 » 2018-10-14 @ 15:26
Thanks for clearing that up for me, I knew I could count on VOGONS for support! I'm sure this will help a lot of people who are bound to run into the same issue. I'll order the connectors in the next few weeks, perhaps in the future I might design a low-profile 3D printed block adapter that simply plugs into the recessed area of the front panel MIDI port.
bionicle_159
Postby bionicle_159 » 2018-10-14 @ 15:33
*This may come across a bit daft but what is the blue section for? I was under the impression that the notch was just for lining up the connector, not having any electrical relevance.
bionicle_159
Postby Kamerat » 2018-10-14 @ 17:29
bionicle_159 wrote:*This may come across a bit daft but what is the blue section for? I was under the impression that the notch was just for lining up the connector, not having any electrical relevance.
Usually that's connected to the cable shielding.
User avatar
Kamerat
Postby Tiido » 2018-10-18 @ 03:57
Shields and grounds are to be connected only on one end (one connecting to MIDI out) on the MIDI cables to prevent ground loops from happening.
User avatar
Tiido
Return to Sound
Who is online
