Reply 20 of 20, by EdmondDantes
- Member
wrote:Have You actually tried installing the video card drivers? I've seen glitches before with just the standard Microsoft VGA driver.
The problem started when I had the drivers installed. Then I assumed the problem might be a faulty HD or OS due to an unrelated issue and wiped the hard drive.
I will go ahead and double-check though.
@oeuvre ... blinker fluid?
