First post, by gryffinwings
Hi guys, I picked up a Pentium 2 computer, a Gateway G6-400. I picked it up with a lot of 8 computers and servers for a combined price of $40 for all the computers, so essentially a $5 computer. Looks to have a Pentium II 400 MHz CPU, can't really tell what motherboard it has, but it has an ISA slot, came with some weird but probably just office computer cards which I removed and put into antistatic bags, not sure what I want to do with those cards. The problem I have is that the computers power supply looks ragged, some rust on the surface and the old case doesn't use the standard power supply size that I am familiar with. Could someone recommend an appropriate power supply? case recommendations would be great, I'm assuming this is an ATX motherboard, here's some pictures of the computer.
The lot of computers I got, 3 are Core 2 Duos, the racks are Intel Xeon LGA 1366 HP DL 360 G6 and G7
45309857_584186285370421_7125655381799337984_o.jpg?_nc_cat=111&_nc_ht=scontent-lax3-2.xx&oh=f5caef1994ac57edc73213bd57c283e2&oe=5C4758EF
Gateway G6-400
45316233_584188178703565_452516495881142272_o.jpg?_nc_cat=102&_nc_ht=scontent-lax3-1.xx&oh=4f21c16d7356d6ae7db3e4d0df775059&oe=5C855708
45342215_584188142036902_502514210173878272_o.jpg?_nc_cat=109&_nc_ht=scontent-lax3-1.xx&oh=fcdec48cb721ddeee9e34686c599fb6a&oe=5C863D91
45269582_584197898702593_5699257233393582080_o.jpg?_nc_cat=102&_nc_ht=scontent-lax3-1.xx&oh=50b57a415f0249720320ff1a9318f097&oe=5C77C63D
45224970_584197955369254_609919226144096256_o.jpg?_nc_cat=110&_nc_ht=scontent-lax3-1.xx&oh=ca87161af8da0cfca5a9afba90937b53&oe=5C823012
45230858_584198002035916_6879527187070844928_o.jpg?_nc_cat=111&_nc_ht=scontent-lax3-2.xx&oh=99a7441ff6bf0e803e283ea8ee0a033f&oe=5C47A8C9
45421976_584202505368799_1637526212257513472_o.jpg?_nc_cat=104&_nc_ht=scontent-lax3-1.xx&oh=f828132cc889bbb22af776e2f14127f7&oe=5C7AF77B
45254525_584202468702136_3896956245797502976_o.jpg?_nc_cat=111&_nc_ht=scontent-lax3-2.xx&oh=8c77e417d1b7552bbdce083fe002038d&oe=5C4A2FE3
Main Computer: Custom - Intel 12900K, Asus Nvidia 3080 Ti, 64 GB DDR5.
Retro Computer: Packard Bell Legend I - AMD 286, 640KB RAM
Retro Computer: Shuttle XPC - Pentium 4 2.8 GHz FSB 400 MHz, ATi Radeon 9600 Pro, Sound Blaster Live!, 2GB RAM.
Reply 1 of 6, by yawetaG
The cards look like:
- a network card
- a modem card with integrated speaker (the L-shaped one)
- an ATI 3D AGP graphics card with a memory extension bay (with extension module)
Nothing special or weird really. Probably they are OEM versions.
As for the power supply, it mostly looks rather dirty with caked on dust. A good clean could do wonders, especially because Gateway Power supplies tend to be good quality and last for a long time.
The motherboards are regular ATX. However, in these cases the power supplies incorporate a fan to cool the CPU and tend to be a custom form factor, so replacing it by a new power supply will require finding a cooling solution for the CPU and possibly cutting up the case.
Reply 2 of 6, by gryffinwings
yawetaG wrote:
The cards look like: - a network card - a modem card with integrated speaker (the L-shaped one) - an ATI 3D AGP graphics card wi […]
- a network card
The part that concerns me about the power supply is that when I removed the dust there was some surface rust. I could probably clean the power supply box and repaint it, which I am not opposed to doing, I'd love to get this computer running again, I really doubt there is anything really wrong with this computer. As for cooling, I was thinking on the lines of a case with multiple 120mm fans, especially with fans on the top side part of the case. I can't imagine that this processor needs much directed air flow, as long as it has plenty of fresh cool air coming into the case.
Reply 3 of 6, by ODwilly
Well it is a standard ATX motherboard. If you transplant it into literally any standard ATX case then using a good quality power supply becomes much easier, as well as cooling.
If you want to keep the case but replace the psu then I think Sparkle or Athena Tech, as well as other companies make "matx" and other small size power supplies in the 300watt range,. Which will be overkill for any typical Slot 1 build.
Reply 4 of 6, by gryffinwings
Well, I got the computer to post, so the power supply seems to be ok, I just need to open it up and get some canned air in there. Other than that, I'm thinking about spray painting the old case to freshen it up, The case is a bit scratched up. I was thinking the exterior panels should be white and the inside and interior and chassis should be black.
thoughts?
Reply 5 of 6, by Katmai500
Those gateway 200W power supplies are pretty common and cheap on eBay. I have a few of these era Gateway towers and the 440BX boards have a 3-pin fan header. So you could swap in a standard 20-pin ATX power supply and just replace the CPU heatsink with one with an attached fan and connect it right to the motherboard. I'm pretty sure the mounting holes on the back of the case are standard ATX. The pinout is standard unlike Dell units of the era.
Reply 6 of 6, by gryffinwings
Not sure I am really concerned about heat, the Arctic F8 80mm fan I installed is moving plenty of air. So I think the supplemental air flow should be enough.
