First post, by Nemo1985
Hello everybody.
Today I received a Via C3 800A Mhz (133x6.0) at 1.25v
According to the info I found arount it's probably an Ezra-T, since the classic C3 at 800 mhz is rated v1.65.
The problem is that the mb select automatically to give him v2!
I tried to change the jumpers setting according to the manual but the voltage doesn't change.
The manual for ver2 is here: ftp://infomag.cz/ovladace/manualy/lucky%20sta … /6va694-v20.pdf
I use the A3 bios revision which is, I suppose the latest version.
Any suggestion is appreciated.
Thank you in advance.
Reply 1 of 1, by Nemo1985
A little update, I tried to patch the bios, but nothing changed.
I really can't understand, the cpu is an 800A while the bios keep saying it's 800B (that according to my google search it doesn't exist).
99.76 KiB
Bios screen
231 KiB
Cpu picture
85.07 KiB
Bios voltages
